...235 I am still geting the same ERROR F5-02 , I replaced the Lamp, What else can we do. Also I replaced The board that comes underneath the Lamp, Thank You. Did you clear the code? It's been a while ...
...are: 051, 054, 061, 065, 068, 083, 100, 108, 113, 131, 141, 143, 145, 146, 176, 180 184, 187, 222, ...
...code on sharp ar-235 what is the simulation process now on sharps Make sure the thermistor is clean and ok then press, P, Interrupt, C, Interrupt. It asks for a code, Enter 14 press print then press ...
...óêàþ ïðîãðàìó êàìå235;åîí ä235;ÿ ...
Question about AR-235 Copier
...235 Grayscale Copier: I use Sharp AR-M150 3-in-1 Copier. I was scaning a... I use Sharp AR-M150 3-in-1 Copier. I was scaning a document when suddenly I got a "system error [H4-00]" message with an ...
...235 what does call service code U2-40 mean CRUM chip communication trouble = the chip on the toner cartridge is faulty. 1, Try to clear the code press P, *, C, *, to enter the service simulation, on ...
...code AR 235 MODEL F5-02 = Copy Lamp Lighting Abnormality. Possibilities are blown copy lamp, failure of lamp harness (cable) or the MCU board. You may need to replace either the copy lamp unit or the ...
hi my photocopy AR-235 is showing code H4-00 what will i do Did you try a trouble clear yet?
...Toner/Cartridge No. for Sharp Copier Printer No. AR-5618N Please give me Toner/Cartridge No. for Sharp Copier Printer No. AR-5618N The code for this one is MX235GT. Hope this helps. MX 235 AT MX 235 ...
...235 (photocopy machine) Code F2 02 Description Toner supply failure. The value judged from the actual toner supply hysteresis differs greatly from the toner sensor value. Causes Developing unit ...
2,817 Questions
2,244 Questions
2,161 Questions
2,149 Questions
1,912 Questions
