SOURCE: ACER ASPIRE 3680 WINDOWS ERROR RECOVERY
hi
you said u did try to press F2 or F8 to get to bios setting, are you saying pressing these would not open bios setting windows?
shakeel
SOURCE: Windows startup error
If it is Windows Vista and it happened after a Windows Update, you might have the problem as described in Microsoft Knowledge Base article KB946084. No matter what you do (any F8 option such as Safe Mode or Command Prompt, or trying to boot from a Vista CD) you end up at the Blue Screen of Death.
Something is corrupted on the hard drive (not a hardware error) and now Vista has a fit if it sees the drive, even as a secondary or external drive (it goes to the BSOD with STOP: 0x0000C1F5).
The only solution so far is to erase the Vista partition and re-install Vista. You can take the drive and connect it to another computer running XP (using an external drive enclosure for example) to get the data off of it. Then do a format on the partition. Now reinstall the drive and you can load Vista. If you have no Vista disk but there was a Recovery Partition, this will now work.
SOURCE: Dell dimension blue screen stop error
When you start up computer press F12 to force computer to load from CD/DVD rom . Once it detects cd follow on screen instructions. If for some reason it doesn't work then try another cd , might need cleaning or try another CD/DVD rom if you have more the one in you system.
SOURCE: Reaccuring boot problem in vista
HII
i got one answer in web
please check out this
if this not help you
we can move furthur http://www.kqzyfj.com/click-3245371-10520244
SOURCE: Blue screen of death
Taken from Microsoft themselves ( http://support.microsoft.com/kb/555302 )
SYMPTOMS
When booting up to Win XP you may get a error that reads "Unmountable Boot
CAUSE
1.The file system is damaged and cannot be mounted.
2.You use a standard 40-wire connector cable to connect the UDMA drive to the controller instead of the required 80-wire, 40-pin cable.
3.The basic input/output system (BIOS) settings are configured to force the faster UDMA modes.
RESOLUTION
If it be the connector cable problem then replace the 40-wire cable with an 80-wire UDMA cable.
If it's a BIOS settings problem then load the 'Fail-Safe' default settings, and then reactivate the most frequently used options such as USB Support.
If it's a damaged file system case then:-
1.Insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted.
2.When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
3.If you have a dual-boot or multiple-boot computer, select the installation that you must access from the Recovery Console.
4.When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
5.At the command prompt, type chkdsk /r , and then press ENTER.
6.At the command prompt, type exit , and then press ENTER to restart your computer.
This takes a bit longer, but the system should boot back into Windows.
