Ruud UAKA037 Air Conditioner Logo
Posted on Aug 18, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Rudd UKA-037JAZ How many Ton is this unit
Horace Gardner
Level 2:
Scholar:
  • Expert 125 Answers
  • Posted on Sep 09, 2011
Horace Gardner
Expert
Level 2:
Scholar:
Answers
125
Questions
Helped
41642
Points
259
1helpful
My rudd uaka 037JAZ leaks, like to replace just AC and not coil and furnace motor. Replacement suggestion for this unit? Homeowener George
Hello, it depends where the unit is leaking from, if it is leaking from the condensing unit then you can just replace the condenser, however if it is leaking from the evaporator coil then you will need to replace the evaporater. As far as brand for replacement I like rheem equipment. The best thing to do is have a hvac technician come out and give you a estimate on a new AC and then you can make a decision.
1helpful
I HAVE A WEATHERKING MODLE WAKA-037JAZ OUTSIDE AC UNIT WITH SPLIT GAS FURNACE-WHAT TON IS THIS UNIT
It appears you may have a 5ton unit, if your house is over
2000sq. feet then Im guessing that 60 thats appears in
the model number is equal to 5ton. 12,000 btus per ton
of cooling
1helpful
Hello, I have a 1.5 ton rudd ac/heat pump
Your outside unit is not defrosting. You need to call a service tech to check it out. Defrost board sensor or low on gas. Also you amy have an outside tstat that is not working correctly. Rus
9helpful
Ruud UAKA-037JAZ A/C How do i determine how many ton unit it is?
its a 3 ton i went to ruud and looked it up for you.
I recently bought a 4 ton 14.5 SEER Rudd Spilt system using R-410 and matching Rudd furnace. This system replaced a Lennox 10 SEER 4 ton unit. Now that it has gotten hot in Baton Rouge LA 90-93 degrees....
Sounds like the Unit might be low on charge.But without correct readings not sure.
The new unit with 410 will actually cool better due to higher boiling point temp. of freon type.Poor air circulation could also cause problem.Such as dirty filter, too slow fan speed,dirty coil.Also could have obstruction in freon lines either at pump,in line set,or in coil.
Get someone u trust to check it out and ask for their Rudd Dealership Training Credentials.
I have a Rudd uaka-037JAZ. I was cutting my lawn and accidentally cut the small wires going to the unit. I reconnected the wires but the unit will not come on.
You possibly shorted out the indoor transformer. The primary side of the transformer will open/burn up when low voltage wiring is shorted. But if indoor unit comes on i.e fan motor works and you cant hear contactor come on on the outside unit you may still have and open circuit on those wires you broke. If you hear the contactor hum or come on you may have a problem with incoming power to the outdoor unit or a pitted contactor. Try those things first.
Top Ruud Heating & Cooling Experts
jdthefixer
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
