Bosch Logixx WFT 2806 Front Load Washer/Dryer Logo
Posted on Aug 22, 2011
Error code F09 on a Bosch Logixx 8 Sensitive - what does that mean? Model WTS86512SN/08.
5 Related Answers
Anonymous
  • Posted on Oct 03, 2010
SOURCE: bosch logixx 6 sensitive, is
Try taking of the back (middle) cap (torque screwdriver). On top of the heating element, you'll find a red (safety) button. Press till click sound.
That is all.
Anonymous
  • Posted on Jan 15, 2010
SOURCE: Bosch washing machine logixx 8 front loader error
Det er for koldt i rommet, eller vandrør har frosset til.Sett opp temperatur i rommet eller tine rør
Anonymous
  • 414 Answers
  • Posted on Jul 07, 2010
SOURCE: f:23 code logixx edition75
Usually means there is water in the base pan and the flood safety has been activated. If you tip the unit forward a touch you will most likely find that water is expelled from the bottom front. The machine should work but obviously the source of the leak has to be found. Check door gasket for tears etc, water valves and drain hoses.
Hope this helps.
Anonymous
  • 15935 Answers
  • Posted on Sep 16, 2010
SOURCE: My Bosch washing machine (logixx
F37 is because of operating the unit below specified temperatures.
Pressing the temperature button twice shows a snowflake and sets a defrost function.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Silverdragon
electronic & computer repair& servicre
  • 12061 Answers
  • Posted on Apr 01, 2011
SOURCE: F42 is showing on my
An error code of "F42" means your oven has a defective or jammed lower latch, latch motor or latch switch, which is preventing the lower oven's latch from locking properly. If all of the electrical connections are in place on your oven's power board, you may have a faulty power board.
Top Bosch Washing Machines Experts
Sudeep Chatterjee
Sudeep Chatterjee
vince
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
