Haier 45-Pint Dehumidifier Logo
Posted on Aug 24, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
E2 error - Haier 45-Pint Dehumidifier
Anonymous
Level 3:
Brigadier General:
  • Master 4,736 Answers
  • Posted on Aug 24, 2011
Anonymous
Master
Level 3:
Brigadier General:
Answers
4736
Questions
0
Helped
2144011
Points
14644
Unfortunately, for whatever reason, Haier does not list the Error Codes and what the problem is, in their Owner's Manuals. To find out what E2 indicates you will have to contact Haier Customer Support
1-877-337-3639. It's very important to have your Model Number handy before you call.
Hope this helps you to get the answer. Thanks for choosing FixYa.
What does an E2 code mean? How can I solve that error? I have a Honeywell Dehumidifier model TP70WKN that is about a year old. It have been working well until now that start showing "E2"at the display
Step 1: Reset the printer
  1. With the printer turned on, disconnect the power cord from the rear of the printer.
  2. Wait at least 60 seconds.
  3. Reconnect the power cord to the rear of the printer.
  4. Turn ON the printer, if it does not automatically turn on.
  5. Wait until the printer is idle and silent before you proceed.
Step 2: Update the printer firmware
Click here to know different methods of updating printer firmware.
Step 3: Printing Documents
You can resolve the error by canceling the print job, and then changing the print settings in the printing software.
I HAVE A RIVA COLD UNIT IT IS WORKING FINE NUT DISPLAYS E2 ERROR COMPRESSOR MODEL CAJ95132
Reset the system read your owner manual section troubleshooting or download from www.retrevo.com or www. manualslib.com
God bless you
My Danby dehumidfier model DDR2510E showed the code E2 after I emptied it and now won't work and no where in my manual does it say what to do or what it means.
Hi There,
The E2 error you are receiving is likely the float switch sensor when turns the system off when the bucket is full. Please contact our customer service department to be connected with a service depot in your area.
1-800-263-2629 Business hours are Monday to Friday 9am-4pm
Thank you!
4helpful
2answers
My dehumidifier is showing an E2 code on it. It is a brand new haier, can you help me out with this problem?
E2 Code indicates a Sensor Error automatic shutdown. To find out which sensor it is you will have to call Haier Customer Support 1-877-337-363.
In the meantime, turn the unit OFF & unplug it for 15 minutes. Then plug the unit back in and turn ON. ON. Hopefully the unit reset itself and reverted back to the original factory settings. And you can set te humidity extraction level where you desire. If the error code reappears, definitely contact Haier, as youtr unit is still under warranty.
1helpful
Quit running and displays E2 in the F/C window.
E2 error indicates that the air intake filter needs to be removed and cleaned. Turn the Master ON/OFF Switch to OFF and unplug the unit, before removing the filter. If you wash the filter, it must be completely dry, before reinstalling it. DO NOT run the dehumidifier without the clean filter installed.
Hope this helped you to solve the problem. Please let me know. Thanks.
3helpful
3answers
Haier 45 Pint Electronic Dehmidifier Error Code E2
Jason, currently the only 45 pint dehumidifier that Haier sell is Model # DE45EK or DE45EK-L or EK-T. If any of those matches the Model Number of yours, you can down load and print the Owners Manual from the link below. However, the model numbers I listed make no reference to Error Code E2. If your Model Number does not correspond to any of those numbers, your unit is probably no longer manufactured or available.
http://www.haieramerica.com/en/asset/product/4ba7175e54
With that said, there are two things you can do. First, turn the Master ON/OFF Switch to OFF. Unplug the unit from the wall outlet and wait 12 - 15 minutes. Then, plug the unit back in and turn the Master On/Off Switch to ON. Did the Error Code clear itself. If so, set the controls as you normally would.
If that didn't solve the problem you can contact Haier Customer Service at 877-337-3639 and they will advise you what to do, to clear the error code.
1helpful
My Duracraft DD-TEC10E dehumidifier has come up with an E2 message that I cannot clear to make it work, any ideas?
DIY fix for Duracraft TEC10E E2 error, in case it's useful for others:
(When I tried to get a replacement temperature sensor via UK/Ireland support (kaz.com -> www.hot-europe.com) I was told that a replacement sensor was not available, nor was my unit serviceable).
Anyway, after a bit of messing with a variable resistor, I found that it would trigger E2 at a resistance of 560-580K, and also at resistance < ~1K (I stupidly destroyed the faulty temperature sensor trying to take it apart, without first checking what kind of resistance it presented, so I don't know whether mine broke OC or shorted).
Assuming an NTC thermistor, and a threshold of 0degC - the sensor is just to stop the dehumidifier cooling coil from icing up AFAIK - a 150K NTC thermistor with 'B'(25/100) value of 4400 should give a suitable replacement, with a 0degC resistance of 579K.
I wasn't able to find an exact such replacement, but I got a 150K/B~4000 from Maplin, put a 170K resistor in series, sheathed it up and installed it, and initial results look good - putting an ice-cube on the new sensor will trigger an E2 on the unit.
YMMV.
2answers
What does an E2 code mean? I have a Haier Dehumidifier that is about a year old, I emtied the bucket and put the bucket back into place and hit the start button and nothing happen I unplugged the unit and...
I have a Haier Dehumidifier that is about a year old, I emtied the bucket and put the bucket back into place and hit the start button and nothing happen I unplugged the unit and error code E2 keeps comming on
Danby ddr401 dehumidifier reading 'E2' error code on screen.
Check the wiring that runs below the fan for nicks and cuts. I had this error code and was in the process of junking my dehumidifier when I noticed the wiring going from the capacitor to the compressor and a few other wires had somehow been chaffed and cut by the fan blade. I had already thrown the control panel away by this time so I don't know if replacing those wires would have cleared the code or not.
Top Haier Dehumidifiers Experts
ADMIN Andrew
ADMIN Andrew
Are you a Haier Dehumidifier Expert? Answer questions, earn points and help others
