Http://www.sharpusa.com/CustomerSupport/ProductDownloads.aspx?model=XE-A406
It took me a while to find the Windows 7 64-bit driver for the XE-A506, but apparently it is located under the XE-A406 version. Eventually, this one worked for me: but don't forget to run the program as administrator (properties - compatibility - "Run this program as an administrator").
By the way, the manual was a bit unclear on how to install the drivers (for me at least). This is the whole process that actually got it working in my case:
And again, don't forgot to Run as Administrator when starting the software: without this, I still couldn't upload data to the device.
SOURCE: Sharp XE-A203 software compatibility with vista 64-bit
to get the register to communicate with your vista or to even run the customer support tool software you will need to uninstall, reinstall, right click on the icon on your desktop, choose properties,in the compatibility box put a checkmark in the "Run this program as administrator",
everything should operate normal now with no errors
SOURCE: How to program the Sharp XE-A12 cash register
here is a link to the software.
there is not enough space here to type instructions, its 90 pages long.
you will need a sd card or usb cable to connect to your puter.
http://www.sharp.ca/downloads/default2.asp
