Hi.
Error AE is prompted when there is a leak detected at the base of the appliance or when the anti flood safety device gets activated.
Disconnect power by unplugging power cord or resetting circuit breaker.
While power is off remove any water present at the base of the appliance.
If there is no water, check the pressure switch, wiring and control board for faults that may result in error AE. Check also setting of the drain hose at the back (it may cause siphoning), and make sure that inlet valve is not leaking.
Regards.
Ginko
