SOURCE: start button problem
You will need the new & improved select button assembly and you can order them through us if you like.
We have full details, plus *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
The order form is at http://207.234.249.73/mwd/btn_form.htm
SOURCE: sharp carousel microwave model # 508ak has power
9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section.
Q - My microwave is running and sounds like it is working but will not heat up anything.
A - Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay.....
Q - The microwave display counts down and the inside light is on, but nothing is heating and the fan is not running.
A - This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common.
thanks.
SOURCE: I have a Sharp Microwave R-520 KS. And it stopped
Did you disconnect and test the three latch assembly microswitches with a multimeter or continuity tester? The top and bottom switch are normally-open, and the middle switch normally-closed. The lower switch seems to be the one that takes a beating and most often fails. It should be an Omron D3V-16G-3C25 and can be found on eBay for $10, or via an electronic parts supplier.
