Televison & Video Logo
Posted on Sep 06, 2011
I need to program my RCA RC44K/49K-T1-01 to my philips DVD player, but I lost the control guide. Can you please help?
5 Related Answers
Anonymous
  • 17 Answers
  • Posted on Oct 30, 2008
SOURCE: lost program guide for rcr3273 rca universal remote need codestoo
Go to thompsontv.com/carc.html
Anonymous
  • 150 Answers
  • Posted on Jul 08, 2007
SOURCE: RCA RCU403 3-Device trying to control GPX DVD player???
It may not be able to run the GPX dvd player as GPX is not a mainstream brand, if you have the original GPX remote, you might purchase a learning remote that can copy remote codes from the original, I have seen these Learning Remotes from around $20 by Phillips Magnavox if I remember correctly.
Anonymous
  • Posted on Feb 29, 2008
SOURCE: PROGRAMING MY TOSHIBA REMOTE TO CONTROL MY RCA DVD
I forgot the pin code on the remote, how can I over ride it?
Jesse Hassan
  • 54 Answers
  • Posted on Aug 17, 2008
SOURCE: im using the rca rcr312w
  1. These instructions come from the RCA website. The crucial step is to keep pressing the reverse button.
  2. Turn on the component (the tv, dvd, etc).
  3. Hold the TV (or DVD) button and the on/off button at the same time. It will stay lit.
  4. Press the play button every five seconds until the component turns off.
    • Each time the Play button is pressed, the illuminated ON-OFF button blinks ten times and a block of 10 codes is sent to your component. This process continues until all the codes in the Code Lists have been searched. If the component has not turned off after all codes have been searched, the illuminated ON-OFF button blinks four times, turns off, and the Auto Code Search Entry method is exited.
  5. When the component turns off, press and release the REVERSE button, then wait two seconds to see if the component turns on again.
  6. If the component does not respond, continue to press the REVERSE button EVERY TWO SECONDS UNTIL THE COMPONENT TURNS ON again. This will isolate the correct code in the last block of codes sent. Each time the REVERSE button is pressed, the illuminated ON-OFF button blinks.
    • If the REVERSE button is accidentally pressed after the component responds, press and release the FORWARD button. Wait two seconds to see if the component turns off again.
  7. To save the new code, press and release the STOP button.
  8. The illuminated ON-OFF button turns off. You must press the STOP button to save the code.
A
Anonymous
  • Posted on Sep 27, 2008
SOURCE: HOW TO PROGRAM RCA RCU310 Remote Control
Thanks the instructions worked out fine...Much appreciation !!
Top RCA Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
