SOURCE: code 93 saltwater system
Hi, Code 93 is telling you that the system is done running, did you mean to say it said 92? That code would be for too much salt. If indeed it is a Code 92 you are getting, give Intex a call, or email. I have found their website to be very helpful, they have a F&Q's area. Good luck!
SOURCE: I am starting an above the ground pool with a salt water system
25 pounds per 1,000 gallons or 3 kg per 1,000 liters of water.
SOURCE: Low salt alarm on Intex system
I had the same problem and my father just kept adding salt wo telling me and it kept saying low salt-I called intex they said to clean the cell with vinegar as instructed in book, and if that didnt help to call back for a warranty claim on the unit bc I just purchased mine in June. I am currently waiting on it to come in. We had to drain half the pool and refill with water and start over. be careful!
SOURCE: how to clean a salt water system
I think this is metal scale. If you dont have your manual, consider asking your dealer for advice. If there is no dealer in your area, consider a mild acid wash.
SOURCE: I have forgotten how to set my salt water system
Could be a couple of things. Have you put the right amount of salt in according to the tables (I find I always have to add a bit more then the tables say). Have you let the salt mix completly by stirring up any salt laying on the bottom of the pool and by running the pump for at least 24 hours before turning on the salt generator. Depending on how large the pool is you may need more than 24 hours before turning on the salt generator. If still doesnt work than you can try adding more salt a little bit at a time over a couple of days. Also check to see if the electrolytic plates need cleaning. Unscrew the large grey connector to the left of where the wire goes into the sensor and look inside the unit on the left)
