Vacuums Logo
Posted on Sep 11, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I replace the power cord on an electrolux 8502A vacuum cleaner?
  • 4 more comments
  • greytandy Sep 11, 2011
    Step 1 is the problem. I removed all the Philips head screws I see but I can't seem to pry the top off the vacuum cleaner head plate. There's something still holding the plate to the head. I can't see any other screws. Maybe there are some clips I need to press?
    Tried "plunking". No luck. The cover is still being held on by something next to the very large wheels.
    Tried "plunking". No success. The cover appears to be attached next to the big wheels.
    I have tried to remove the wheels with enough force to not break them, but no luck. There's virtually no space between the wheels and the body.
  • greytandy Sep 12, 2011
    Do you know how to get the cover off the vacuum cleaner so I can get access to the motor?
    Step 3 is the issue. I have removed all visible screws but can only get the cover partially separated. I cannot see what is holding it together inside for fear of breaking the piece. I need a step-by-step guide on how to take the cover off of the Electrolux 8502A vacuum cleaner to expose the motor.
Anonymous
Level 3:
  • Master 670 Answers
  • Posted on Sep 11, 2011
Anonymous
Master
Level 3:
Answers
670
Questions
0
Helped
161906
Points
1915
1 Unplug the vacuum and remove all accessories such as extensions and brushes. Open the vacuum's outer casing to get at the end of the power cord. Exactly how you will do this depends on the model of vacuum. Generally it simply involves the removal of two to three Phillips-head screws.
2 Follow the power cord to the two connections at the vacuum's motor. Unfasten any clips or holding bracket and disconnect the cord from the motor. Sometimes this can be accomplished by unscrewing two connection screws, other times the cord is soldered directly to the motor. If this is the case use wire cutters and cut the cord about 4 inches from the motor to give room for splicing on a new cord.
3 Insert the new power cord into the vacuum. Follow the exact same path as the old one. If there were any brackets or clips that held the old cord in place inside the vacuum or out use them on the new cord.
4 Tie a knot in the cord on the inside of the vacuum casing so that it will not accidentally be pulled out of the motor once it is in use.
5 Connect the new cord to the motor in the same fashion as the old one. With wire strippers take off about 1 inch of insulation from the new cord to expose the two wires. Either wrap them around the connection posts and re-screw, or twist the new cord wires around the 4-inch remnants of the old cord and seal all exposed wire and connections with electrical tape.
6 Replace the vacuum's casing in reverse order from how you removed it. Plug in the vacuum to test.
  • 1 more comment
  • Anonymous Sep 11, 2011
    Most likely there is. Check if you plunk the sides of the cover to open it up.
    can you try removing the wheels so you can check what's holding it inside? just make sure you remember how you dismantled it as they should be put back in the same way ok.
  • Anonymous Sep 12, 2011
    the cover could be glued in there or something. But check the outer edge and see if you can insert the head of a flat screw driver and take it off.
Michael Vincent Cruz
Level 3:
Guru:
  • Master 868 Answers
  • Posted on Sep 12, 2011
Master
Level 3:
Guru:
Answers
868
Questions
Helped
278421
Points
2414
I can't find a manual or info on how to replace the part you need, but then here is a link where you can get info on where to get service for the repair.
Anonymous
Level 3:
  • Master 957 Answers
Anonymous
Master
Level 3:
Answers
957
Questions
Helped
275589
Points
2857
The electrical cord of an Electrolux Vacuum can wear out or become damaged just like it can for other tools and appliances. Generally, the damage is to the outer rubber casing of the cord and is caused by friction, twisting and age. Because the damage can expose the wires inside, unrepaired cords can cause further damage to the vacuum, prevent it from working and cause electrical shock to the user.
1.Unplug the vacuum cord to avoid electric shock. Make sure the machine is free of any attachable implements, such as hoses and nozzles. This allows easy access to the casing surrounding the cord's entrance.
2.Locate the casing surrounding the cord's entrance into the vacuum.
3.Remove the casing by unscrewing the screws. The number and location of the screws differs depending on the model of Electrolux vacuum you have.
4.Remove all of the fasteners, clamps or pins that secure the cord inside of the vacuum. Note how the cord is attached inside the vacuum, as you install the new cord in the same way.
5.Find where the cord splits into wires and attaches to the vacuum's motor. Most cords will divide into two wires.
6.Loosen the screws that hold the wires of the old cord to the motor. If the wires are soldered to the motor, cut the old cord 4 to 6 inches from the soldered end. This will allow enough cord to splice the new cord on.
7.Place the new cord into the vacuum following the exact same route as the old one.
8.Replace the fasteners, clamps or pins to secure the new cord into place.
9.Remove 1 inch of the insulation from the new cord with wire strippers. This exposes the individually wrapped wires inside. Remove the insulation around the individual wires as well.
10.Shape the new wires into small hooks using the needle nose or lineman's pliers. This helps you connect them to the motor. Wrap the hooks of the wires around the connection screws and tighten the screws. If the wires are soldered to the motor and you will need to splice the cord, skip this step and proceed to the next step.
11.Splice the new cord onto the old and strip the wire tips of the remaining old cord 1 inch. Connect the wires of the new and old cord by twisting together the pairs of wires with matching color. Sealing each wire connection by wrapping it in electrical tape. Seal the entire splice with electrical tape.
12.Reattach the casing and tighten the screws to hold it in place.
Top Vacuums Experts
AskDyson
AskDyson
ADMIN Andrew
ADMIN Andrew
Are you a Vacuum Expert? Answer questions, earn points and help others
