SOURCE: Ubuntu doesn't see internet/router
Hvae you tried setting tie network manually in Ubuntu?
Network Manager is used in many sections of this guide - you can find it:
Connecting using Wireless in Network Manager
Network Manager (System → Administration → Network) supports Roaming mode. This allows you to connect to any available wireless network in range.
Connecting to a hidden network
This section is about setting up an ADSL Internet connection using an ethernet PPPoE modem.
You will require a subscription with an Internet Service Provider, and an installed, functional Internet connection. Most modems have a light which will be lit if it is currently connected to the Internet. You will also need your username and password for the Internet account.
Setting up PPPoE
To set up the modem:
Starting the connection
To start your ADSL connection on demand, in a terminal (Applications → Accessories → Terminal) type:
sudo pppoeconf
sudo pon dsl-provider
Stopping the connection
To stop your ADSL connection, in a terminal (Applications → Accessories → Terminal) type:
sudo poff dsl-provider Hope this helps.If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: FB Password Reset helpline Call 1-8O5-225-669O We are 24 Hour Available Call Now
Do you have an account on facebook? If not create before logging into it, if have that please tell what error are you getting while logging into it.
SOURCE: https://login.facebook.com/login.php?login_attempt...
It means that facebook has a fault Try navigating to http://facebook.com and logging in.
SOURCE: hi, i need solution with
I assume this is not a problem with your router, sounds like a software problem to me instead. There's a number of things you can try. First of all, empty your browser's cache and try again. Most of the time this will get rid of similar problems.
SOURCE: https://www.facebook.com/login.php?login_attempt=1
internet search type in facebook login you should see a tab forgot password
hope this helps you
