Denon DN-T625 CD Player Logo
Posted on Sep 15, 2011
TOC error code - Denon DN-T625 CD Player
Cd player shows toc err
google the name clarion error code toc
1helpful
Ive just got a mini disk player and its comeing up toc error,can you help me please
Probably not. There are various reasons that TOC errors occur, some are fixable and others not, but Sharp MD units were really known to suffer from them for multiple reasons all at once. TOC means Table Of Contents; it's an index file on the disc which tells the host machine where everything on the disc is located and the TOC is modified whenever you edit a disc. Sometimes the file gets corrupted, but often the machine itself simply becomes unable to read the disc and as the TOC is the first thing it tries to read then you get a TOC error.
If you're lucky the TOC error is limited to a single minidisc; if this is the case then it's just one faulty disc and although there are ways to perform TOC cloning they usually involve hacking the host machine in various ways which may cause permanent damage. Unless the disc is important, just chuck it away and use a new one. If the fault is with the player then again, just chuck it into the nearest electronic waste recycling bin. Spares are not available, and as it's a Sharp, diagnosis will be difficult and the fault likely to return.
Many MD players are practically worthless these days so they're often available on FreeCycle and Freegle groups: Sony are the preferred choice by far, and are also the most commonly offered brand, but take whatever is on offer without complaint and worry about problems later; after all, they are free.
4helpful
2answers
TOC ERRORa
When you FINISH recording, the Minidisc recorder Writes the TOC (Table of Contents) - so you see it flashing TOC or Update when you finish recording - you need to Leave POWER ON and have the unit on for about 30 seconds for it to finish this. IF you don't, the unit doesn't know where to find the files since there is no TOC. Try a Sony home unit - you might get one more shot at it working with that.
I am getting a toc error while trying to burn cds
Reinstall CD burning software and check.Also try to burn the CD in safe mode to check.
3helpful
3answers
TOC eror
The TOC error is the same error seen on computer disks, TOC is the table of content, this has to be read before the the unit will know the details of tracks etc......
If every disk inserted (not just burned discs) has this error, the laser is faulty or out of alignment. Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
TOC ERROR
mine too can anyone help?what did u do
2helpful
2answers
TOC error message
Unit displays TOC error when I inserted two new cds I purchased.
1helpful
TOC error
toc stands for table of contents error if it is a copied cd it is probably how it was written if not do other cds work?
chris
Top Denon Audio Players & Recorders Experts
woodzowl307
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
