MSI 661FM3-V Motherboard Logo
Anonymous Posted on Sep 17, 2008
Driver where can i get msi motherboard driver? MSI 661FM3-V Motherboard
  • Anonymous Sep 19, 2008
    motherboard- msi
    ms 7103
    sis 964
    661fm3-v
    All these are on motherboard,which driver i need for my computer.Pls .
  • eslam_wahba2 May 06, 2009
    i need drivers for MSI MS-7103 661FM3-V
Anonymous
Level 2:
  • Expert 31 Answers
  • Posted on May 08, 2009
Anonymous
Expert
Level 2:
Answers
31
Questions
0
Helped
93951
Points
156
MSI 661FM3 V
Link Download :
SiS® 650/650GL/651/661FX/740/761GX/67x VGA Drivers
XP :
Vista :
SiS® 650/650GL/651/661FX/740/761GX/67x System Drivers
XP :
Vista :
Realtek ALC Series AC97 Audio Driver
XP :
XP64bit :
SiS IDE Drivers
XP :
MSI 661FM3 V (PCB V2.0)
SiS SATA Driver (For floppy driver)
XP/vista :
XP :
Vista :
XP :
Vista :
XP :
XP64bit :
SiS IDE Drivers
XP :
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 333 Answers
  • Posted on Sep 17, 2008
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
333
Questions
0
Helped
120064
Points
908
You might find the drivers here. suggest you try the live update.
http://global.msi.com.tw/index.php?func=downloadindex
    Have you tried the live update on the MSI site? I cannot do this for you as it is specific to MSI boards. Is your computer working at the moment? If you can, I suggest that you download all the drivers on offer.
    Let me know what happens.
    cheers
A
Anonymous
Install PC wizard address below. Run & find out your REQUIRED driver number.
Visit that manufacturer's home page. search for that driver.
Install.
If you can't get it visit Driverguide listed below. Become a free member & download the driver & install.
Source(s): http://pc-wizard-2008.en.softonic.com http://members.driverguide.com/driver/
http://forums.whatthetech.com/
2 Related Answers
bronk50
Brian Sullivan
  • 27725 Answers
  • Posted on Apr 16, 2011
SOURCE: i need sata driver for
which sata driver for the cd/dvd drive ot sata hard drive
if you are having trouble with your drivers
here is a general look at the drivers and how to update them
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver hope this helps
Anonymous
  • 55 Answers
  • Posted on Apr 22, 2009
SOURCE: i need to connect h.d sata with motherboard msi 661fm3-v
I assume you mean how.
Reakky sata is easy, Just clip on to the right port and plug power. Your system shoud be able to autodetect it. Just make sure that you go into th bios and make sure that sata is enabled.
2helpful
Msi n1996 661fm3 graphics card
Hi, you can download the driver here:
http://www.msi.com/product/mb/661FM3-V--PCB-2-0-.html#/?div=Driver&os=XP%2032
Please select your operating system.
Click on the graphic driver and download.
Unzip the file before installation.
You maybe have to install the system driver first.
1helpful
2answers
I need the install cd or where to find the drivers for MS-7103 v.1, 661fm3. Thanks.
Hi, you can download the drivers here at MSI:
http://www.msi.com/product/mb/661FM3-V.html#/?div=Driver&os=Vista%2032
But there is to different versions of your product.
Here is the other one:
http://www.msi.com/product/mb/661FM3-V--PCB-2-0-.html#/?div=Driver&os=Vista%2032
Remember to select your operating system.
Or you can download and install the live update function from here:
http://www.msi.com/service/download/
This will download your drivers needed.
Hope this will help you.
I need sata driver for 661fm3-v msi motherboard
Want sound
Download here at Msi:
http://www.msi.com/product/mb/661FM3-V.html#/?div=Driver&os=XP%2032
Unzip the file before you install.
Good luck
2helpful
Ethernet controller driver msi 661fm3-v windows 7
Download here at msi:
The ethernet driver is in System & Chipset Drivers
Click on zip file for download
Unzip before you install
You need reboot after this
Good luck
7helpful
Cant detect MSI 661FM3-V LAN driver for win7
eventually through continued research, i found out that this is a common issue with several mobo ang win7... SIS driver for LAN was the answer. i just downloaded the driver then install manually. although there is still no driver support intended for win7 as of the moment, vista driver does the trick...
4helpful
XP is Not Recognizing Sata H.D. and I Need a RAID Controller Driver
This one should be right for you, remember to put it on a floppy, since XP needs a floppy for a 3rd party driver during install.. good luck!
http://download1.msi.com/files/downloads/dvr_exe/sis_sataraid_floppy_mb.zip
I need to connect h.d sata with motherboard msi 661fm3-v
Top MSI Computers & Internet Experts
Sudeep Chatterjee
Sudeep Chatterjee
Grand Canyon Tech
Grand Canyon Tech
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
