Canon DC330 DVD Camcorder Logo
Anonymous Posted on Oct 11, 2011
How can I edit my video disc - Canon DC330 DVD Camcorder
Anonymous
Level 1:
New Friend:
  • Contributor 9 Answers
  • Posted on Oct 17, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
9
Questions
0
Helped
5177
Points
27
For DVD camcorders, it depends on your DVD discs type. Some kinds are edited and finalized on camcorders and can be never modifyed once you finished. In this case you must consider carefully before editing on camcorders and finish it. Other discs allow you to rewrite on it with editing programs like ArcSoft ShowBiz.
I don't know if your camcorder have features to edit videos in camcorder itself, while some camcorders can. If it dosen't, you need to edit DVD videos on computer with an editor such as ArcSoft ShowBiz. And you need to check your DVD disc style at first. Some discs support rewriting so you can shoot a video, edit it, delete it, shoot a new one all on one disc. Some don't, once you finalize it, nothing can be modifyed. For those rewritable discs, ShowBiz is really a good choice, which enables you to edit disc frames, customize buttons, layers, etc. It even support blu-ray discs editing and burning.
2helpful
How can I view and Edit a from an 8mm Video Camcorder Cannon UC5500 to LG HDMI digital TV?
Things you need to do is:
1. Put your 8 mm disc in your computer;
2. Make use of a editing program to open up the videos on discs and edit it;
3. Output your after-edit videos as you like, such as burn a DVD disc or save back to your camcorder.
You can connect your camcorder with digital TV using its special line, or play back discs in DVD player. However, to get the best HD effects, you need more equippments.
Use a powerful editing software like ArcSoft ShowBiz 5 to cover the task. Their website www.arcsoft.com/showbiz supplies free-of-charge version in 30 days.
How to burn video cd?
Many of these drives came withdriver and video editing software that includes writing the final product.to a dvd. My LG drive came with cyberlink video software. This allows loading video files in many different formats, editing using the included tools to add titles, cut out parts not wanted, setting chapters, then produce by burning to the drive onto a blank dvd disc. Blanks come in dvd-r , dvd+r , and dvd-rw formats. The disc will play on dvd players. When you look at the disc with your computer, all you can see are the marker names. You cannot copy files from video discs. Other video editing software are: Cyberlink, Roxio, Etc... If you need product software, go to the link and enter your drive model number. http://msa.lge.com/product_listing?pageIndx=0&pagerId=0&catalogId=285&orig=index&md2psid=2-131468373284123264
1helpful
I was just wondering, IF the PS2 can play games that have been edited on a computer/laptop (e.g. 4-disc PS1 game put onto one disc), and not edited as in the actual game disc being edited, but put on a...
Your system needs a mod chip to play games on a disc that was not created by Sony.
Most ps2 games are DVD's only some are cd's.. All of the ps1 games are cd's so if you burnt it onto a dvd its not going to work.
Can't download videos from Hitachi 3200A from Ram-disc.
If you mislay the accessories, it is hardly fair to blame the manufacturer
4helpful
Format a cd
First some explanations:
The Canon DC210 will only take 'minus' format DVDs (DVD-R, DVD-R DL and DVD-RW). Only the DVD-RW must be formatted (initialised) before use. During initialisation you'' be asked whether you want to initialise the disc in VIDO mode or in VR mode.
VIDEO mode: Once finalised discs recorded in VIDEO mode can be played back in most common DVD players, offering the best compatibility. However, recordings cannot be edited (deleted, rearranged etc) on the camcorder.
VR mode: You can easily edit the recordings on the camcorder. However, discs recorded in VR mode can only be played back with DVD players that are compatible with DVD-RW discs in VR mode.
My preference is Video mode - I can then play the disc on a DVD player and edit it on a PC.
Now, to initialise a DVD-RW
1. Press the 'FUNC.' key
2. Use the joystick to select 'MENU' - it's in the bottom left corner of the screen
3. Use the joystick to select 'DISC OPERATIONS'
4. Use the joystick to select 'DISC INITIALIZE'
5. Use the joystick to select either 'VIDEO' or 'VR' mode
6. Use the joystick to select 'YES' to confirm your choice
7. Use the joystick to select 'YES' to start initialising the disc
Close the menu only after the screen display returns to the 'DISC OPERATIONS' menu.
Don't forget to rate this solution once you've tried it !
2helpful
Not recognizing mini dvdrw
DVD-R discs can be used with no preparation, but a DVD-RW must be initialised before it can be used for the first time.
You may also have to initialise a DVD-RW if you get the message "UNABLE TO RECOGNIZE THE RECORDING MODE OF THE DISC" .
Also, make sure you always use DVD "minus" format discs - the DC210 will not work with any DVD "plus" format discs.
When you initialise the disc you will be asked to chose between Video mode and VR mode. Most DVD players will play a Video mode disc, but a VR mode disc can be edited with the camcorder. My preference is Video mode - I can then play on a DVD player and edit on a PC.
Sony mini dvd disc
Experiment with other software(s).
2answers
Zenith xbr411 DVD recorder
See the manual, page 8:
What are “Recording modes”? for DVD-RW
There are two recording modes available using this
recorder: VR mode and Video mode. When recording to
a DVD-R disc, recordings are always in Video mode.
DVD-RW discs can be formatted for VR mode recording
or Video mode recording.
VR mode recording
• 4 different picture quality/recording time settings available
(SP, LP, EP, XP)
• Not playable on regular DVD players
• Recordings can be extensively edited
• Total number of titles on the disc should be less than
99.
(SP, LP, EP, XP)
• Playable on regular DVD players (after finalizing)
• Limited editing features
99.
Note :
DVD-Video Format (Video mode) is a new format for
recording on DVD-R/RW discs that was approved by
the DVD Forum in 2000. You may therefore experience
problems playing recordable DVD discs in some players.
Symptoms include video artifacts, audio and/or
video dropouts and playback suddenly stopping.
Our company cannot take responsibility for problems
playing discs recorded on this VCR/DVD Recorder in
other players.
Do the DVD-Cams have any editing functions?
Yes: Delete, Play List, Move, Divide, Combine and Fade are available when recording onto DVD-RAM discs. This feature is available by utilizing HITACHI’s Disc Navigation System. DVD-R discs cannot be edited.
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
john h
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
