Home Logo
jacob jensen Posted on Nov 14, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why is it flashing fl and why is watercod - Jacuzzi Home
US Parts Center
Level 3:
  • Jacuzzi Master 719 Answers
  • Posted on Feb 13, 2013
US Parts Center
Jacuzzi Master
Level 3:
Answers
719
Questions
0
Helped
290146
Points
1972
FL is used by some for a water flow problem. If you have the error then these are a few things to check.
  • Check for a dirty filter.
  • Check your gate valves on each side of the pump
  • Make sure they are fully open
  • Check the pressure switch to ensure it is operational
if you do not have enough water flow in the system it will not turn on the heater. The heater not being on will obviously allow the tub water to go cold.
Rod
US Parts Center
888-521-6183
Built-in flash and an external flash simultaneously
Yes, please see the following table: Optional Flash Flash Control Mode Capacity FL-50 TTL Auto (Super FP flash)/ TTL Auto/ Auto/ Manual/ Manual (Super FP flash) The FL-50 flash can be connected with the E-300 camera through flash power grip: FP-1 and flash cable: FL-CB05. FL-40 Auto/ Manual The external flash cannot be used with the built-in flash. * Only Auto and Manual mode can be set in the concurrent use of FL-40 and the built-in flash. (For their specification design, E-300 and FL-40 can not communicate in TTL Auto and R-TTL Auto modes.) FL-36 TTL Auto (Super FP flash)/ TTL Auto/ Auto/ Manual/ Manual (Super FP flash) The external flash can be used with the built-in flash.
Connect an FL-20, FL-36, FL-40 or FL-50 external flash
The FL-20, FL-36, FL-40 or FL-50 external flash can be attached directly to the hot shoe on the camera. You also can use the FL-BK01 Flash Bracket and the FL-CB02 Hot Shoe to TTL cable.
Connect these external flashes...
The FL-20, FL-36, FL-40 or FL-50 dedicated external flash can be attached directly to the hot shoe on the camera. To use the FL-20, FL-36, FL-40 or FL-50 flash off-camera, you will need a bracket and appropriate flash cable. Please use the following information as a reference: FL-BK01 Flash Bracket - used to mount an external flash to the C-770 Zoom. FL-CB02 Hot Shoe to TTL Cable - this cable is required for the dedicated FL-20, FL-36, FL-40, or FL-50 flash.
Connect to external flashes
The FL-20, FL-36, FL-40 or FL-50 dedicated external flash can be attached directly to the hot shoe on the camera. To use the FL-20, FL-36, FL-40 or FL-50 flash off-camera, you will need a bracket and appropriate flash cable. Please use the following information as a reference: FL-BK01 Flash Bracket (item #200666) - used to mount an external flash to the C-770 Zoom. FL-CB02 Hot Shoe to TTL Cable (item #200663)- this cable is required for the dedicated FL-20, FL-36, FL-40, or FL-50 flash.
Connect a FL-20, FL-36, FL-40 or FL-50 dedicated external flash
The FL-20, FL-36, FL-40 or FL-50 dedicated external flash can be attached directly to the hot shoe on the camera. To use the FL-20, FL-36, FL-40 or FL-50 flash off-camera, you will need a bracket and appropriate flash cable. Please use the following information as a reference: FL-BK01 Flash Bracket - used to mount an external flash to the C-750 Zoom. FL-CB02 Hot Shoe to TTL Cable -this cable is required for the dedicated FL-20, FL-36, FL-40, or FL-50 flash.
5-pin TTL connector for external flash
The 5-pin TTL connector is designed to control the Olympus FL-40 dedicated flash unit (p/n 200596). To use the FL-40 with these cameras, the optional Olympus FL-CB01 cable (p/n 200 664) and FL-BK01 flash bracket (p/n 200 666) must be used. The 5-pin TTL connector can also control a PC Sync flash or strobe system by using the optional FL-CB04 flash cable (p/n 200 661). Since this type of flash/strobe is non-dedicated, the photographer will need to manually match the flash output with the camera.
The FL-20, FL-36, FL-40 or FL-50 dedicated external flash can be attached directly to the hot shoe on the camera. To use the FL-20, FL-36, FL-40 or FL-50 flash off-camera, you will need a bracket and appropriate flash cable. Please use the following information as a reference: FL-BK01 Flash Bracket (item #200666) - used to mount an external flash to the C-5060 Wide Zoom. FL-CB02 Hot Shoe to TTL Cable (item #200663)- this cable is required for the dedicated FL-20, FL-36, FL-40, or FL-50 flash.
Extension Flash connector terminal
You would use the Extension Flash connector terminal along with the optional flash bracket "FL-BK01" and bracket cable "FL-CB01" so that you can use the Olympus FL-40 dedicated flash. With the use of bracket cable "FL-CB04", you can use another brand extension flash.
2answers
External Flash
Yes, the FL-20 Flash and the FL-36 Flash are both available accessory flashes that cover a wide variety of lighting needs. The FL-50 is designed for advanced to professional photograhphers who need the greatest light output.
Top Jacuzzi Home Experts
john h
vince
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
