Freezers Logo
Dan Linville Posted on Dec 26, 2011
E9 code Model 253.28432809 Code E9 shows on display and freezer runs constantly and gets extremely cold. Cannot raise temp or lower with code on display. Only thing I can do is Lock it or turn it OFF. Need to know what E9 means and how to remove so I can set the Temp?
3 Related Answers
Anonymous
  • 417 Answers
  • Posted on Feb 16, 2008
SOURCE: freezer temp display beeping and going through different temps rapidly!
Seems that you may have a faulty temp control switch or it is stuck in position. Check this also make sure that the air vents are clear.
Thanks J
Anonymous
  • 150 Answers
  • Posted on Apr 23, 2008
SOURCE: Kenmore Upright Freezer Model 253.9239780 Temp alarm, Temp rising slowly
you have a refrigeration issue partner let her go 16 yrs. is good service you can replace it for 3 to 5 hundred the repair will be that IF you can find someone with the r-12. don't go for a top it off and go deal the food you lose is to expensive for that to be economical.
Anonymous
  • 291 Answers
  • Posted on Jul 08, 2009
SOURCE: Kenmore upright freezer alarm sounds constantly
replace the battery in the grill or the hi-voltage control under the unit in the back
Top Kenmore Freezers Experts
jdthefixer
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
