Microwave Ovens Logo
Posted on Oct 06, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I replace the light bulb in a NEFF H7860B1GB/01 ?
  • ichill Oct 06, 2008
    Thanks - Trouble is - this model is not free standing, it's built in.
    Microwave is built-in, and looking inside I can see no way to reach the bulb.
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 298 Answers
  • Posted on Oct 06, 2008
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
298
Questions
0
Helped
117882
Points
821
In the microwave ,on the side of the bulb, there should be a small screw holding a protective panel in place if you remove it you should be able to slide the panel ,and replace the bulb.
monk3ybidzness
Level 3:
  • Master 1,879 Answers
monk3ybidzness
Master
Level 3:
Answers
1879
Questions
Helped
782894
Points
4784
If you’re not able to admire your Yorkshire puddings rising properly, it’s probably time to replace your oven light bulb.
In case you missed it, scroll down and look for the instructions on how to replace the lamp provided by ginko
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 200 Answers
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
200
Questions
0
Helped
46717
Points
549
HI
first remove the plug
and remove a shield or glass dome.
after remove the shield u can remove the tube..
Thank you
Anonymous
Level 3:
  • Master 435 Answers
Anonymous
Master
Level 3:
Answers
435
Questions
Helped
262763
Points
1007
The interior oven light in most ovens is a standard 40 watt appliance bulb. Often, to change the bulb, you first need to remove a shield or glass dome. If the bulb isn't burned out, the problem may be with the switch on the oven door frame. If the switch works poorly, intermittently, or not at all, you need to replace it.
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 331 Answers
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
331
Questions
Helped
111951
Points
863
Try removing the lid .....
by sliding it
and then replace the bulb
Ginko
Level 3:
  • Neff Master 19,396 Answers
Ginko
Neff Master
Level 3:
Answers
19396
Questions
25
Helped
8264276
Points
55462
Unplug power first. You need to remve the screwa that hold the bulb cover, access the bulb and replace it, I will wee if I can find a diagram.
  • Ginko
    Ginko Oct 06, 2008
    Here is the replacement bulb, as you can see it is a regular bulb, once you access it , replacing it is quite easy.
  • Ginko
    Ginko Oct 06, 2008
    Even if it is built in you should still be able to access the glass cover inside the oven, remove it and replace the bulb.
    Here are instructions from Neff manual:
    1. Switch off the oven fuse in the fuse box.
    2. Place a a tea towel in the cold oven to prevent damage.
    3. Remove the glass cover. To do this, press back the metal tab with your thumb.
    4. Unscrew the bulb and replace it with the one of the same type. 40 watt heat resistant spare bulb.
    5. Fit the glass cover back on. To do this, insert it on one side and
    press firmly on the other side. The glass cover will now click into
    place.
    6. Remove the tea towel and switch the fuse back on.
Top Neff Microwave Ovens Experts
john h
ADMIN Andrew
ADMIN Andrew
Larry Ng
Larry Ng
Are you a Neff Microwave Oven Expert? Answer questions, earn points and help others
