Computers & Internet Logo
Anonymous Posted on Feb 16, 2012
Computer memory issue...PLEASE HELP?????
HERE IS THE LONG VERSION: RIPPING MY HAIR OUT TRYING TO FIGURE OUT WHAT KIND OF R.A.M. I NEED? I HAVE ORDERED 6 DIFFERENT CONFIGURATIONS AND STILL GET BEEPING NOISE AND NO POWER ON FOR COMPUTER. PLEASE SOMEONE OUT THERE HAD TO HAVE HAD THIS PROBLEM!!!??? ALL THE MAJOR WEB SITES (CRUCIAL,KINGSTON, ETC) RECOMMEND PC3-8500 DDR3 BUT THE FACTORY SHIPPED IT OUT WITH A STRANGE PC3-10700 (667MHZ) 2GB STICK LABLED "GDDR3-1333 2GB 128MX8 1.5V". I JUST WANT TO ADD 2GB OF RAM!. OR BUY 2 NEW 2GB MODULES THAT WILL ACTUALLY WORK. I JUST FOUND THAT GREAT PROGRAM CPU-Z AND IT GIVES OUT ALL THE NUMBER'S THAT PEOPLE LIKE ME CAN BARELY COMPREHEND. I'LL TRY TO POST THE FRONT BUS SPEED / MOTHERBOARD AND JEDEC? TIMINGS? BIOS IS ACER VERSION P01-B1 (12/16/2010) AND HERE ARE THE NUMBERS WITH THE REALLY BORING STUFF TAKEN OUT. ANY HELP WOULD BE GREAT: CPU-Z TXT Report ------------------------------------------------------------------------- Binaries ------------------------------------------------------------------------- CPU-Z version 1.59 Processors ------------------------------------------------------------------------- Number of processors 1 Number of threads 2 APICs ------------------------------------------------------------------------- Processor 0 -- Core 0 -- Thread 0 0 -- Core 1 -- Thread 0 1 Processors Information ------------------------------------------------------------------------- Processor 1 ID = 0 Number of cores 2 (max 2) Number of threads 2 (max 2) Name Intel Pentium E6700 Codename Wolfdale Specification Pentium(R) Dual-Core CPU E6700 @ 3.20GHz Package (platform ID) Socket 775 LGA (0x0) CPUID 6.7.A Extended CPUID 6.17 Core Stepping R0 Technology 45 nm TDP Limit 65 Watts Core Speed 1597.9 MHz Multiplier x FSB 6.0 x 266.3 MHz Rated Bus speed 1065.3 MHz Stock frequency 3200 MHz Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T, VT-x L1 Data cache 2 x 32 KBytes, 8-way set associative, 64-byte line size L1 Instruction cache 2 x 32 KBytes, 8-way set associative, 64-byte line size L2 cache 2048 KBytes, 8-way set associative, 64-byte line size FID/VID Control yes FID range 6.0x - 12.0x Max VID 1.288 V # of P-States 0 Thread dumps ------------------------------------------------------------------------- CPU Thread 0 APIC ID 0 Topology Processor ID 0, Core ID 0, Thread ID 0 Type 01008006h Max CPUID level 0000000Dh Max CPUID ext. level 80000008h Cache descriptor Level 1, D, 32 KB, 1 thread(s) Cache descriptor Level 1, I, 32 KB, 1 thread(s) Cache descriptor Level 2, U, 2 MB, 2 thread(s) CPUID (DELETED FOR BREVITY) CPU Thread 1 APIC ID 1 Topology Processor ID 0, Core ID 1, Thread ID 0 Type 01008006h Max CPUID level 0000000Dh Max CPUID ext. level 80000008h Cache descriptor Level 1, D, 32 KB, 1 thread(s) Cache descriptor Level 1, I, 32 KB, 1 thread(s) Cache descriptor Level 2, U, 2 MB, 2 thread(s) CPUID (DELETED FOR BREVITY) Chipset ------------------------------------------------------------------------- Northbridge Intel G41 rev. A3 Southbridge Intel 82801GB (ICH7/R) rev. A1 Memory Type DDR3 Memory Size 2048 MBytes Channels Single Memory Frequency 532.6 MHz (1:2) CAS# latency (CL) 7.0 RAS# to CAS# delay (tRCD) 7 RAS# Precharge (tRP) 7 Cycle Time (tRAS) 20 Row Refresh Cycle Time (tRFC) 60 Command Rate (CR) 1T MCHBAR I/O Base address 0x0FED14000 MCHBAR I/O Size 4096 MCHBAR registers (DELETED FOE BREVITY) Memory SPD ------------------------------------------------------------------------- DIMM # 1 SMBus address 0x50 Memory type DDR3 Module format UDIMM Manufacturer (ID) (7F7F7F7F7F7F7F07) Size 2048 MBytes Max bandwidth PC3-10700 (667 MHz) Part number GU512303EP0202 Manufacturing date Week 08/Year 11 Number of banks 8 Nominal Voltage 1.50 Volts EPP no XMP no JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency JEDEC #1 6.0-6-6-17-23 @ 457 MHz JEDEC #2 7.0-7-7-20-27 @ 533 MHz JEDEC #3 8.0-8-8-22-30 @ 609 MHz JEDEC #4 9.0-9-9-25-34 @ 685 MHz DIMM # 1 SPD registers 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 00 92 10 0B 02 02 11 00 09 03 52 01 08 0C 00 3C 00 10 69 78 69 30 69 11 20 89 70 03 3C 3C 00 F0 83 81 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 30 00 00 00 00 00 00 00 00 00 00 00 00 0F 11 01 01 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 70 00 00 00 00 00 07 07 00 11 08 00 00 00 00 AB A7 80 47 55 35 31 32 33 30 33 45 50 30 32 30 32 00 00 90 00 00 00 00 02 FE 00 00 00 00 00 00 00 00 00 00 A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Monitoring ------------------------------------------------------------------------- Mainboard Model Veriton X275 (0x000003FD - 0xC35094A0) LPCIO ------------------------------------------------------------------------- LPCIO Vendor ITE LPCIO Model IT8721 LPCIO Vendor ID 0x90 LPCIO Chip ID 0x8721 LPCIO Revision ID 0x1 Config Mode I/O address 0x2E Config Mode LDN 0x4 Config Mode registers 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 00 00 00 00 00 00 00 00 04 00 00 00 00 00 00 00 00 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 20 87 21 01 00 00 40 0C 31 00 17 00 00 03 00 00 00 30 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 60 0A 10 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 70 00 02 00 00 04 04 00 00 00 00 00 00 00 00 00 00 Register space LPC, base address = 0x0A10 Hardware Monitors ------------------------------------------------------------------------- Hardware monitor ITE IT8721 Voltage 0 11.98 Volts [0xF0] (+12V) Voltage 1 5.00 Volts [0xEE] (+5V) Voltage 2 1.08 Volts [0x5A] (CPU VCORE) Voltage 3 1.67 Volts [0x8B] (VIN3) Voltage 4 2.02 Volts [0xA8] (VIN4) Voltage 5 1.38 Volts [0x5C] (+3.3V) Voltage 6 2.82 Volts [0xEB] (VIN6) Voltage 7 1.66 Volts [0x8A] (VIN7) Voltage 8 1.57 Volts [0x83] (VIN8) Temperature 0 42°C (107°F) [0x2A] (CPU) Temperature 1 45°C (113°F) [0x2D] (Mainboard) Temperature 2 27°C (80°F) [0x1B] (TMPIN2) Fan 0 1140 RPM [0x250] (CPU) Fan PWM 0 0 pc [0x0] (FANPWM0) Fan PWM 1 0 pc [0x0] (FANPWM1) Fan PWM 2 0 pc [0x0] (FANPWM2) Register space LPC, base address = 0x0A10 DELETED FOE BREVITY Hardware monitor ACPI Temperature 0 27°C (80°F) [0xBBA] (THRM) Temperature 1 50°C (122°F) [0xCA0] (THRS) PCI Devices ------------------------------------------------------------------------- Description Host Bridge Location bus 0 (0x00), device 0 (0x00), function 0 (0x00) Common header Vendor ID 0x8086 Model ID 0x2E30 Revision ID 0x03 PI 0x00 SubClass 0x00 BaseClass 0x06 Cache Line 0x00 Latency 0x00 Header 0x00 PCI header Subvendor ID 0x1025 Subsystem ID 0x0407 Int. Line 0x00 Int. Pin 0x00 PCI capability Caps class Vendor Dependant Caps offset 0xE0 PCI registers BLAH BLAH Description VGA Controller Location bus 0 (0x00), device 2 (0x02), function 0 (0x00) Common header Vendor ID 0x8086 Model ID 0x2E32 Revision ID 0x03 PI 0x00 SubClass 0x00 BaseClass 0x03 Cache Line 0x00 Latency 0x00 Header 0x00 PCI header Address 0 (memory) 0xFE400000 Address 2 (memory) 0xD0000000 Address 4 (port) 0x0000EC00 Subvendor ID 0x1025 Subsystem ID 0x0407 Int. Line 0x00 Int. Pin 0x01 PCI capability Caps class Message Signalled Interrupts Caps offset 0x90 PCI capability Caps class Power Management Caps offset 0xD0 Caps version 1.1 PCI capability Caps class 0x13 Caps offset 0xA4 PCI registers (DELETED FOR BREVITY) Description Multimedia device Location bus 0 (0x00), device 27 (0x1B), function 0 (0x00) Common header Vendor ID 0x8086 Model ID 0x27D8 Revision ID 0x01 PI 0x00 SubClass 0x03 BaseClass 0x04 Cache Line 0x08 Latency 0x00 Header 0x00 PCI header Address 0 (memory) 0xFEAF8000 Subvendor ID 0x1025 Subsystem ID 0x0407 Int. Line 0x10 Int. Pin 0x01 PCI capability Caps class Power Management Caps offset 0x50 Caps version 1.1 PCI capability Caps class Message Signalled Interrupts Caps offset 0x60 PCI capability Caps class PCI Express Caps offset 0x70 Device type Root Complex Integrated Endpoint Device Port 0 Version 1.0 Link width 0x (max 0x) PCI registers (DELETED FOR BREVITY) Description PCI to PCI Bridge Location bus 0 (0x00), device 28 (0x1C), function 0 (0x00) Common header Vendor ID 0x8086 Model ID 0x27D0 Revision ID 0x01 PI 0x00 SubClass 0x04 BaseClass 0x06 Cache Line 0x08 Latency 0x00 Header 0x81 PCI header Primary bus 0x00 Secondary bus 0x01 Int. Line 0x00 Int. Pin 0x01 PCI capability Caps class PCI Express Caps offset 0x40 Device type Root Port of PCI-E Root Complex Port 1 Version 1.0 Physical slot #4 Presence detect yes Link width 1x (max 1x) PCI capability Caps class Message Signalled Interrupts Caps offset 0x80 PCI capability Caps class Subsystem Vendor Caps offset 0x90 SubVendor ID 0x1025 SubSystem ID 0x0407 PCI capability Caps class Power Management Caps offset 0xA0 Caps version 1.1 PCI registers (DELETED FOR BREVITY) Description USB Controller (UHCI) Location bus 0 (0x00), device 29 (0x1D), function 0 (0x00) Common header Vendor ID 0x8086 Model ID 0x27C8 Revision ID 0x01 PI 0x00 SubClass 0x03 BaseClass 0x0C Cache Line 0x00 Latency 0x00 Header 0x80 PCI header Address 4 (port) 0x0000E880 Subvendor ID 0x1025 Subsystem ID 0x0407 Int. Line 0x17 Int. Pin 0x01 PCI registers (DELETED FOR BREVITY) Description USB Controller (UHCI) Location bus 0 (0x00), device 29 (0x1D), function 1 (0x01) Common header Vendor ID 0x8086 Model ID 0x27C9 Revision ID 0x01 PI 0x00 SubClass 0x03 BaseClass 0x0C Cache Line 0x00 Latency 0x00 Header 0x00 PCI header Address 4 (port) 0x0000E800 Subvendor ID 0x1025 Subsystem ID 0x0407 Int. Line 0x13 Int. Pin 0x02 PCI registers (DELETED FOR BREVITY) Description USB Controller (UHCI) Location bus 0 (0x00), device 29 (0x1D), function 2 (0x02) Common header Vendor ID 0x8086 Model ID 0x27CA Revision ID 0x01 PI 0x00 SubClass 0x03 BaseClass 0x0C Cache Line 0x00 Latency 0x00 Header 0x00 PCI header Address 4 (port) 0x0000E480 Subvendor ID 0x1025 Subsystem ID 0x0407 Int. Line 0x12 Int. Pin 0x03 PCI registers (DELETED FOR BREVITY) Description USB Controller (UHCI) Location bus 0 (0x00), device 29 (0x1D), function 3 (0x03) Common header Vendor ID 0x8086 Model ID 0x27CB Revision ID 0x01 PI 0x00 SubClass 0x03 BaseClass 0x0C Cache Line 0x00 Latency 0x00 Header 0x00 PCI header Address 4 (port) 0x0000E400 Subvendor ID 0x1025 Subsystem ID 0x0407 Int. Line 0x10 Int. Pin 0x04 PCI registers (DELETED FOR BREVITY) Description USB 2.0 Controller (EHCI) Location bus 0 (0x00), device 29 (0x1D), function 7 (0x07) Common header Vendor ID 0x8086 Model ID 0x27CC Revision ID 0x01 PI 0x20 SubClass 0x03 BaseClass 0x0C Cache Line 0x00 Latency 0x00 Header 0x00 PCI header Address 0 (memory) 0xFEAF7C00 Subvendor ID 0x1025 Subsystem ID 0x0407 Int. Line 0x17 Int. Pin 0x01 PCI capability Caps class Power Management Caps offset 0x50 Caps version 1.1 PCI capability Caps class Debug Port Caps offset 0x58 PCI registers (DELETED FOR BREVITY) Description PCI to PCI Bridge Location bus 0 (0x00), device 30 (0x1E), function 0 (0x00) Common header Vendor ID 0x8086 Model ID 0x244E Revision ID 0xE1 PI 0x01 SubClass 0x04 BaseClass 0x06 Cache Line 0x00 Latency 0x00 Header 0x01 PCI header Primary bus 0x00 Secondary bus 0x02 Int. Line 0xFF Int. Pin 0x00 PCI capability Caps class Subsystem Vendor Caps offset 0x50 SubVendor ID 0x1025 SubSystem ID 0x0407 PCI registers (DELETED FOR BREVITY) Description PCI to ISA Bridge Location bus 0 (0x00), device 31 (0x1F), function 0 (0x00) Common header Vendor ID 0x8086 Model ID 0x27B8 Revision ID 0x01 PI 0x00 SubClass 0x01 BaseClass 0x06 Cache Line 0x00 Latency 0x00 Header 0x80 PCI header Subvendor ID 0x1025 Subsystem ID 0x0407 Int. Line 0x00 Int. Pin 0x00 PCI capability Caps class Vendor Dependant Caps offset 0xE0 PCI registers (DELETED FOR BREVITY) Description IDE Controller Location bus 0 (0x00), device 31 (0x1F), function 1 (0x01) Common header Vendor ID 0x8086 Model ID 0x27DF Revision ID 0x01 PI 0x8A SubClass 0x01 BaseClass 0x01 Cache Line 0x00 Latency 0x00 Header 0x00 PCI header Address 4 (port) 0x0000FFA0 Subvendor ID 0x1025 Subsystem ID 0x0407 Int. Line 0x00 Int. Pin 0x01 PCI registers (DELETED FOR BREVITY) Description IDE Controller Location bus 0 (0x00), device 31 (0x1F), function 2 (0x02) Common header Vendor ID 0x8086 Model ID 0x27C0 Revision ID 0x01 PI 0x8F SubClass 0x01 BaseClass 0x01 Cache Line 0x00 Latency 0x00 Header 0x00 PCI header Address 0 (port) 0x0000E080 Address 1 (port) 0x0000E000 Address 2 (port) 0x0000DC00 Address 3 (port) 0x0000D880 Address 4 (port) 0x0000D800 Subvendor ID 0x1025 Subsystem ID 0x0407 Int. Line 0x13 Int. Pin 0x02 PCI capability Caps class Power Management Caps offset 0x70 Caps version 1.1 PCI registers (DELETED FOR BREVITY) Description SMBus Controller Location bus 0 (0x00), device 31 (0x1F), function 3 (0x03) Common header Vendor ID 0x8086 Model ID 0x27DA Revision ID 0x01 PI 0x00 SubClass 0x05 BaseClass 0x0C Cache Line 0x00 Latency 0x00 Header 0x00 PCI header Address 4 (port) 0x00000400 Subvendor ID 0x1025 Subsystem ID 0x0407 Int. Line 0x0B Int. Pin 0x02 PCI registers (DELETED FOR BREVITY) Description Ethernet Controller Location bus 1 (0x01), device 0 (0x00), function 0 (0x00) Common header Vendor ID 0x14E4 Model ID 0x1690 Revision ID 0x01 PI 0x00 SubClass 0x00 BaseClass 0x02 Cache Line 0x00 Latency 0x00 Header 0x00 PCI header Address 0 (memory) 0xFEBF0000 Subvendor ID 0x1025 Subsystem ID 0x8000 Int. Line 0x0A Int. Pin 0x01 PCI capability Caps class Power Management Caps offset 0x48 Caps version 1.2 PCI capability Caps class Vendor Dependant Caps offset 0x60 PCI capability Caps class Message Signalled Interrupts Caps offset 0x50 PCI capability Caps class PCI Express Caps offset 0xCC Device type PCI-E Endpoint Device Port 0 Version 2.0 Link width 1x (max 1x) PCI registers (DELETED FOR BREVITY) DMI ------------------------------------------------------------------------- DMI BIOS vendor Acer version P01-B1 date 12/16/2010 DMI System Information manufacturer Acer product Veriton X275 version unknown serial PSVAM03034113062F12703 UUID {628827D0-0712-1120-0330-040017000000} DMI Baseboard vendor Acer model Veriton X275 revision unknown serial U01U111306456 DMI System Enclosure manufacturer Acer chassis type Desktop chassis serial unknown DMI Processor manufacturer Intel model Pentium(R) Dual-Core CPU E6700 @ 3.20GHz clock speed 3200.0 MHz FSB speed 267.0 MHz multiplier 12.0x DMI Extension Slot designation PCIE1 type A6 populated no DMI Extension Slot designation PCIE2 type AA populated no DMI OEM Strings string[0] Intel G41+ICH7 DMI Physical Memory Array location Motherboard usage System Memory correction None max capacity 4096 MBytes max# of devices 2 DMI Memory Device designation DIMM0 format DIMM type unknown total width 64 bits data width 64 bits size 2048 MBytes DMI Memory Device designation DIMM1 format DIMM type unknown Graphics ------------------------------------------------------------------------- Number of adapters 1 Graphic APIs ------------------------------------------------------------------------- API Intel I/O Display Adapters ------------------------------------------------------------------------- Display adapter 0 Display name \\.\DISPLAY1 Name Intel(R) G41 Express Chipset Memory size 830 MB PCI device bus 0 (0x0), device 2 (0x2), function 0 (0x0) Vendor ID 0x8086 (0x1025) Model ID 0x2E32 (0x0407) Performance Level 0 Software ------------------------------------------------------------------------- Windows Version Microsoft Windows 7 (6.1) Service Pack 1 (Build 7601) DirectX Version 11.0 ACPI (THIS IS REALLY LONG BUT NOT SURE IF IT HELPS) ------------------------------------------------------------------------- ACPI Tree _GPE _L0A _L1B _L09 _L0B _L1D _L03 _L04 _L0C _L0E _L0D _L05 _L00 _L06 _PR_ P001 HI0_ HC0_ HT0_ _PDC _OSC _PPC _PCT _PSD _PSS SPSS NPSS CPU1 P002 _PPC _PCT _PSD _PSS SPSS NPSS CPU2 P003 CPU3 P004 CPU4 _SB_ PR00 AR00 PR01 AR01 PR04 AR04 PR05 AR05 PR06 AR06 PR07 AR07 PR08 AR08 PR09 AR09 PRSA PRSB PRSC PRSD PRSE PRSF PRSG PRSH PCI0 _HID _ADR _BBN _UID _PRT _S3D _CID MCH_ _HID _UID _CRS NPTS NWAK P0P2 _ADR _PRW P0P3 _ADR _PRW P0P1 _ADR _PRW _PRT SBRG _ADR IELK _HID RXA0 [ ] [ ] PBLV [ ] [ ] PBMS [ ] PMCS ECNS [ ] ECT1 ELEN [ ] _STA SMOD GPBS SPTS SWAK APMP [ ] APMC APMS [ ] [ ] [ ] BRTC PMS0 [ ] [ ] RTCS [ ] WAKS [ ] PWBT [ ] SMIE [ ] [ ] PS1E [ ] PS1S [ ] PIC_ _HID _CRS DMAD _HID _CRS TMR_ _HID _CRS RTC0 _HID _CRS SPKR _HID _CRS COPR _HID _CRS UAR1 _UID _HID _STA _DIS _CRS _SRS _PRS CMPR UAR2 _UID _HID _STA _DIS _CRS _SRS _PRS CMPR FDC_ _HID _FDE _STA _DIS _CRS _SRS _PRS LPTE _HID _STA _DIS _CRS _SRS _PRS LPPR EPPR PS2K _HID _CID _STA _CRS _PRW _PSW PS2M _HID _CID _STA M2R0 M2R1 _CRS _PRW _PSW SIOR _HID _UID CRS_ _CRS DCAT IKEY KBFG MSFG UR1F ENFG EXFG LPTM UHID ORF0 ORF1 ORF2 ANF0 ANF2 ANF4 STF0 STF1 SIOS SIOW SIOH IOID [ ] INDX DATA [ ] [ ] LDN_ [ ] OP29 [ ] ACTR [ ] IOAH IOAL IOH2 IOL2 [ ] INTR [ ] DMCH [ ] OPT0 OPT1 OPT2 OPT3 OPT4 CGLD DSTA DCNT CRS1 IRQM DMAM IO11 IO12 LEN1 CRS2 IRQE DMAE IO21 IO22 LEN2 IO31 IO32 LEN3 DCRS DSRS RMSC _HID _UID CRS_ _CRS HPET _HID CRS_ [ ] HPTS [ ] HPTE [ ] _STA _CRS LPCR RX80 [ ] [ ] LPCD LPCE DBPT DDLT RRIO WX82 RDMA FWH_ _HID CRS_ BS00 BL00 BS10 BL10 _CRS FWHE _HID _UID CRS_ _CRS FHR0 [ ] FHD1 [ ] FHD0 OMSC _HID _UID CRS_ CRS1 _CRS PIX0 TPM_ _HID _CID _UID _CRS _STA TAAX MIPT [ ] PSMI PPI1 PPI2 MBUF BUF0 BUF1 BUF2 BUF3 _DSM PCIE _HID _UID CRS_ _CRS IDE0 _ADR REGF _REG TIM0 TMD0 PIO0 DMA0 PIO1 DMA1 CHNF CFG2 [ ] PMPT PSPT PMRI [ ] SMPT SSPT SMRI [ ] PSRI SSRI [ ] PM3E PS3E SM3E SS3E [ ] PMUT [ ] PSUT [ ] **** [ ] SSUT [ ] [ ] PM6E PS6E SM6E SS6E PMCR PSCR SMCR SSCR [ ] PMAE PSAE SMAE SSAE GMPT GMUE GMUT GMCR GSPT GSUE GSUT GSCR CHN0 _ADR _GTM _STM DRV0 _ADR _GTF DRV1 _ADR _GTF CHN1 _ADR _GTM _STM DRV0 _ADR _GTF DRV1 _ADR _GTF GTM_ STM_ AT01 AT02 AT03 AT04 ATA0 ATA1 ATA2 ATA3 ATAB CMDC GTFB GTF_ RATA NATA IDE1 _ADR REGF _REG TIM0 TMD0 PIO0 DMA0 PIO1 DMA1 CHNF CFG2 [ ] PMPT PSPT PMRI [ ] SMPT SSPT SMRI [ ] PSRI SSRI [ ] PM3E PS3E SM3E SS3E [ ] PMUT [ ] PSUT [ ] **** [ ] SSUT [ ] [ ] PM6E PS6E SM6E SS6E PMCR PSCR SMCR SSCR [ ] PMAE PSAE SMAE SSAE GMPT GMUE GMUT GMCR GSPT GSUE GSUT GSCR CHN0 _ADR _GTM _STM DRV0 _ADR _GTF DRV1 _ADR _GTF CHN1 _ADR _GTM _STM DRV0 _ADR _GTF DRV1 _ADR _GTF GTM_ STM_ AT01 AT02 AT03 AT04 ATA0 ATA1 ATA2 ATA3 ATAB CMDC GTFB GTF_ RATA USB0 _ADR BAR0 [ ] USBW [ ] _S3D _PSW CRRD [ ] ARFG UHUB _ADR IUSB OUSB UPT6 _ADR _UPC UPT8 _ADR _UPC _PRW USB1 _ADR BAR0 [ ] USBW [ ] _S3D _PSW CRRD [ ] ARFG UHUB _ADR IUSB OUSB UPT6 _ADR _UPC UPT8 _ADR _UPC _PRW USB2 _ADR BAR0 [ ] USBW [ ] _S3D _PSW CRRD [ ] ARFG UHUB _ADR IUSB OUSB UPT6 _ADR _UPC UPT8 _ADR _UPC _PRW USB3 _ADR BAR0 [ ] USBW [ ] _S3D _PSW CRRD [ ] ARFG UHUB _ADR IUSB OUSB UPT6 _ADR _UPC UPT8 _ADR _UPC _PRW EUSB _ADR CRRD [ ] ARFG EHUB _ADR IUSB OUSB EPT6 _ADR _UPC EPT8 _ADR _UPC _PRW MC97 _ADR _PRW P0P4 _ADR _PRW _PRT P0P5 _ADR _PRW _PRT P0P6 _ADR _PRW _PRT P0P7 _ADR _PRW _PRT LANE _ADR _PRW P0P8 _ADR _PRW _PRT P0P9 _ADR _PRW _PRT SUPP CTRL _OSC GFX0 _ADR IGDM [ ] SIGN SIZE OVER SVER VVER GVER MBOX DMOD [ ] KSV0 KSV1 [ ] IBTT IPSC IPAT [ ] IBIA IBLC [ ] ITVF ITVM [ ] IDVM IDVS ISSC PAVP CSTE NSTE [ ] DRDY CSTS CEVT [ ] DIDL DDL2 DDL3 DDL4 DDL5 DDL6 DDL7 DDL8 CPDL CPL2 CPL3 CPL4 CPL5 CPL6 CPL7 CPL8 CADL CAL2 CAL3 CAL4 CAL5 CAL6 CAL7 CAL8 NADL NDL2 NDL3 NDL4 NDL5 NDL6 NDL7 NDL8 ASLP TIDX CHPD CLID CDCK SXSW EVTS CNOT NRDY [ ] SCIE GEFC GXFC GESF [ ] PARM DSLP [ ] ARDY ASLC TCHE ALSI BCLP PFIT CBLV BCLM CPFM EPFM PLUT PFMB DDCV [ ] GVD1 PHED BDDC TCOI [ ] [ ] [ ] SCIS [ ] DBTB GSCI GBDA SBCB IGDP [ ] [ ] [ ] GIVD [ ] GUMA [ ] [ ] GMFN [ ] [ ] CDCT [ ] [ ] ASLE [ ] GSSE GSSB GSES [ ] [ ] CDVL [ ] [ ] LBPC [ ] ASLS M512 M1GB PDRD PSTS OSYS GNOT GHDS GLID GDCK PARD AINT SCIP OPBS OPTS OWAK MCHP [ ] [ ] TASM [ ] CRS_ MIN5 MAX5 LEN5 MIN6 MAX6 LEN6 MIN7 MAX7 LEN7 _CRS TVID [ ] VIDT ITPM _HID _CID _UID _CRS _STA TAAX MIPT [ ] PSMI PPI1 PPI2 MBUF BUF0 BUF1 BUF2 BUF3 _DSM BN00 SLPS SLPB _HID _STA SBEV _PRW RMEM _HID _UID CRS_ _CRS PWRB _HID _UID _STA _PRW BUFA IRA0 LNKA _HID _UID _STA _PRS _DIS _CRS _SRS LNKB _HID _UID _STA _PRS _DIS _CRS _SRS LNKC _HID _UID _STA _PRS _DIS _CRS _SRS LNKD _HID _UID _STA _PRS _DIS _CRS _SRS LNKE _HID _UID _STA _PRS _DIS _CRS _SRS LNKF _HID _UID _STA _PRS _DIS _CRS _SRS LNKG _HID _UID _STA _PRS _DIS _CRS _SRS LNKH _HID _UID _STA _PRS _DIS _CRS _SRS XCPD XNPT XCAP XDCP XDCT XDST XLCP XLCT XLST XSCP XSCT XSST XRCT MUTE RBPE RWPE RDPE WBPE WWPE WDPE RWDP RPME WMID _HID _UID _WDG TSBF BB01 BB02 OBRH TBNH _WED WMBK WMBL FRTN PHSR BTOM MTOB XALL CPBF FR72 AWMI [ ] [ ] MW00 [ ] [ ] MD00 [ ] [ ] MQ00 [ ] MAR0 MAR1 MB01 MB02 PSMX SMI0 [ ] SMIC RCMS [ ] CIND CDTA _SI_ _TZ_ THRM _CRT _TMP THRS _CRT _TMP _REV _OS_ _OSI _GL_ DP80 DP90 SPIO IOPB IOPL IOEB IOEL IOGB IOGL IOSB IOSL APIC PMBS PMLN GPBS GPLN SMBS SMBL PM30 SUSW SMIO TPBA TPBL TPMB TOBS SUCC NVLD CRIT NCRT LIDS CHST DVMT PCIB PCIL SMIT CMRQ CMER CMOR SWSM SNUM VERT COBR BIOS [ ] SS1_ SS2_ SS3_ SS4_ [ ] IOST TOPM ROMS MG1B MG1L MG2B MG2L [ ] DMAX HPTA CPB0 CPB1 CPB2 CPB3 ASSB AOTB AAXB SMIF DTSE DTS1 DTS2 MPEN TPMF MG3B MG3L MH1B MH1L OSTP RRIO RDMA PICM _PIC OSVR OSFL MCTH PRWP GPRW WAKP DEB0 [ ] DBG8 DEB1 [ ] DBG9 OSYS FZTF [ ] PIRA PIRB PIRC PIRD [ ] PIRE PIRF PIRG PIRH IP__ [ ] SSIN SSDA HTLT HTLS KELV RTMP RTMS TPOL [ ] TPO1 HGIO [ ] [ ] HQAA SIOR [ ] SIND SDTA [ ] [ ] SLND [ ] PSKB [ ] [ ] ALTF [ ] LEDW FREQ ENCG EXCG KBRW [ ] KBCA [ ] [ ] [ ] KBCB WOTB WSSB WAXB _PTS _WAK _S0_ _S3_ _S4_ _S5_ PTS_ WAK_ SSDT CSDT TSDT CFGD NCPU NPCP PDC0 TBL0 CTB0 TTB0 PSTE TSTE PMRG [ ] [ ] DEV4 DEV5 DEV6 DEV7 STS4 STS5 STS6 STS7
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 17, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
821
Points
Intel[R]G41 EXPress chipset[vendor id=0X806,device id=0x2e32]
1 Related Answer
Anonymous
  • 118 Answers
  • Posted on Mar 23, 2009
SOURCE: Hi,
check compatabilty check online for your board chipset on the www.acer.com/support will find the solution for the upgrade cpu compatabilty, gudday !!
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
