Tools & Hardware - Others Logo
A
Anonymous Posted on Mar 01, 2012
Stanley tr-70 spring has no tension
Unit loads,but will not shoot due to no trigger tension
  • Len Lyttle Jul 22, 2019
    If your TR70 has no Spring pressure look at the bottom where the staples come out if there's that little piece of metal sticking out press it until it goes back and it will snap and you will have Spring pressure again evidently it was dry fired or the last time you used it when you ran out of staples there wasn't enough pressure to push the mechanism that shoots the staple back in I just fixed mine good to go
  • Aileen Richmond
    Aileen Richmond Aug 19, 2022
    Okay, thanks, this worked. However the rubber bumper that causes the trigger to reset has disintegrated. Can I get a replacement?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 11, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
4502
Points
It sounded good but made no sense. How do you remove the trigger/ squeeze handle assembly? This thing (Stanley TR70) is riveted together. The only piece that is removable is the staple feed tray.
  • Anonymous Nov 11, 2012
    Disregard the "makes no sense" comment. I guess I don't understand how to post. I was reply to another post that had an explaination of how to disassemble the TR70 staple gun and it showed up a new thread.
  • cue_vo Sep 25, 2014
    It sounds like your hammer is stuck. If you press down hard on the top of the staple gun while it is in the firing position the hammer should load. You probably have a staple stuck inside or there is gunk build up inside the mechanism. Push and fire the staple gun without staples. Spray it with degreaser or lubricant. Repeat until the hammer loads easily. Hope this helps.
1 Related Answer
Anonymous
  • Posted on Apr 21, 2011
SOURCE: Stanley TR 250 Staple Gun Staple cartridge problem
very simple to fix it 1 pull the trigger all the way out 2 there is a little piece of metal, pull it all the way out (detach the piece out from the gun) an connect one side of the spring 3 push the piece back on the gun. 4 on the other side of the spring tide a little fishing line 5 pass the fishing line over a small rounded piece and pull it hard 6 finally connect the side of the spring onto a little hock on the base of the trigger
Top Tools & Hardware - Others Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
