Goldstar MV-1502 Microwave Oven Logo
Cate Messager Posted on Sep 18, 2006
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Turntable Problem Whenever the microwave door is open, the turntable spins.
  • carol Mar 29, 2012
    Omg! My Panasonic Microwave does the exact same thing. And I have just opened the door while food is warming or cooking all the time! What can I do?? What did you do?
Anonymous
Level 1:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Oct 10, 2007
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
5
Questions
0
Helped
15817
Points
5
Check the turntable motor if there is water inside the motor will turn when the door is open. i have had this happen on some sharp microwaves
William Miller
Level 3:
  • Goldstar Master 9,179 Answers
  • Posted on Sep 18, 2006
William Miller
Goldstar Master
Level 3:
Answers
9179
Questions
Helped
4550754
Points
21750
If it jumps or moves just a little when you open the door, that is normal. It it actually runs, then you have a problem. Quite often this is due to a bad door switch. Opening the door while cooking (without first hitting the STOP button) is the primary cause of door switch failure. You can visit my Web site at _ or e-mail at _ if you'd like more in information on diagnosing and repairing this problem.
3 Related Answers
sharcnet
SHARCNET-USA
  • 2130 Answers
  • Posted on Mar 08, 2008
SOURCE: Turntable does not work
If the rest of the oven works fine, then this indicates that you might have a problem with the motor that turns the turntable.
If you try to turn the turntable manually (gently), does it turn freely or is there resistance? If it turns freely, the mechanical mechanism between the turntable and motor may be broken and the motor may be ok.
The oven's microprocessor also controlls the motor. There could be a problem there.
You'll need to have it looked at by a service center. Although its not that difficult to determine which of the reasons I mentioned above is the cause, it can be however, dangerous to operate a microwave oven with the cover off and with high voltage circuits exposed.
Please let me know if I can be of further assistance to you.
- Jim
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Oct 03, 2008
SOURCE: Over the range Goldstar microwave not working????
(If you need more help than this, please reply back with your model number)
It's probably a bad door switch or door switch mount.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
If you only need a switch, you can order one from us for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Anonymous
  • Posted on Jan 01, 2009
SOURCE: Goldstar MV1501W not heating or turntable, light/display does wrk
micro switch is bad .remove top vent cover 4 screws,after removing plastic vent panel you will see 1 screw above display time window,remove this screw and lift up the complete button time control panel slightly and pull towards you to remove.there are 2 connections on this panel 1 is a 12 pin connector and a 2 pin power connection remove both put control panel aside.now there are 3 micro switches where the door pins close into the oven lock,remove 2 screws that hold the micro switch housing,on the bottom of housing you will see a small clip gently pull to the right and push back to remove .there are 2 switches on bottom of it and 1 on top. the 1 on top is normally open and closes when door is shut but like mine it stayed open and resulted in (light s display but no turntable)soon as i replaced upper microswitch it runs perfect.i hope this helps .MODEL MV1501W GOLDSTAR
Top Goldstar Microwave Ovens Experts
Paul Bade
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
