When desired temp is set int bake mode,temp never changes.
SOURCE: GE Profile JT952 Double Wall Oven
sounds like the heater element needs replacing. But before replacing it or buying one would be a good idea to check your power point (wall socket) to make sure it is okay. Then check the oven wires to make sure there are no burnt or broken wires. Check for fuses that might have blown - some ovens do have fuses. After checking all of these you will need to check to see if you have power getting to the element. If not chances are you have a faulty switch. If you are getting power to the element chances are the element is faulty and will need replacing. Hope this helps.
Regards
Bryan
SOURCE: the oven broiler work but the baking part doesent.
hi thanks for the question I would replace the bottom igniter it has failed thanks the appliance doc
SOURCE: GE Profile Stove baking option not working
Possibly the bake igniter, the temperature sensor or the electronic oven clock/control. Does broil mode heat properly or does it run cool also? If broil heats to the proper temperature then the temperature sensor is probably ok. That leaves the ignitor or the controller which takes some more troubleshooting. If it is the controller, we repair them at www.fixyourboard.com.
SOURCE: my ge jtp56woa1ww double electric
Sounds like the bottom element, or element wire in the top oven is burned out, Check to see if the element is broken, or swollen. Two signs of a burned element.
