Whirlpool Calypso GVW9959K Top Load Washer Logo
Posted on Nov 07, 2008
Error code i have crosley front loader and i notice e70 code pops up on screen any solutions as to what that is and how to solve it
5 Related Answers
Anonymous
  • 4889 Answers
  • Posted on Nov 06, 2007
SOURCE: E70 Error Code
Means you are not getting cold water into unit..Either cold water hose is connected to the wrong hose or cold water faucet is not turned on..You can solve this by connecting hose to cold water faucet and cold water inlet on washer..
Anonymous
  • 770 Answers
  • Posted on Feb 18, 2008
SOURCE: Crosley Front Load Washers FL Error
Flood Condition F L “FL” flashes if any overfill condition occurs. This condition occurs when excessive water in
the tub causes the overfill switch to trip. The control must realize that the trip was due to an
overfill condition instead of a suds lock condition in order for “FL” to be displayed.
With an overfill condition, the beeper repeats a warning every 10 seconds with no time out.
The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch
resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
aborcass
Ron Coons
  • 2651 Answers
  • Posted on Mar 10, 2008
SOURCE: E70 error on Model LTF2940FE1 Front loading washer
good to see you cked that , 1 question though are you by chance using stainless hoses made by company FLOODSAFE. if so theres your problem theres a shut off inside the hose itself that is malfunfuctioning, replace with regular s/s hose and all will be good. if your not usinf a floodsafe hose hten lets go to the next hting- when oyu first start machine, cold water flows in before cycle even starts, can you hear it coming in??? at least trying perhaps a light humm with no water? water vavle is located under main top you can remove the top and check for voltage when trying to fill
Anonymous
  • 3513 Answers
  • Posted on Sep 30, 2009
SOURCE: Samsung J845 front loader washing machine. Error
Hi
An OE error presents if the washing machine has not successfully drained the water in ten minutes.
there are a few simple steps to take before calling for service.
Step 1: Check the drain pump filter.
Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
Step 3: Confirm that the washer is leveled properly.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a level on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
you can perform a diagonal test when leveling the washing machine to ensure that the unit does not tilt from corner to corner.
Thanks for contacting fixya.com
Anonymous
  • Posted on Dec 23, 2009
SOURCE: error code E70 on my Frigidaire front loading
The hot and cold water hoses were connected wrong to the washer.
Narseman
