4. In Virtual memory window --- Select C drive --- Click on custom Size. 5. Change initial size to 2000MB & Maximum size to 4000MB -- Click on Set button.
In Windows XP 1.Click Start, and then click Control Panel. 2.Click Performance and Maintenance, and then click System. 3.On the Advanced tab, under Performance, click Settings. 4.On the Advanced tab, under Virtual memory, click Change. 5.Under Drive [Volume Label], click the drive that contains the paging file that you want to change. 6.Under Paging file size for selected drive, click to Custom size
check box. You can enter the amount of memory you would like to reserve
for Virtual memory by entering the initial and maximum size. 7.Click Set
You can only do that with onboard video cards. If you have an onboard you can choose how much ram to assign to it in your bios settings. However it is limited and if you already have 128 assigned to it, that's probably about all it's gonna give ya. But hey it never hurts to check
Assigning your physical memory to your graphics card will result a shortage of your total system memory and your whole system will slow down a bit. Video cards meant for better processing the graphical content of your system and free up your system's physical memory.[via] So, if you buy a new and better video card with more memory you will have a fast system with better performance.
hello frnd, you can increse your virtual memory manually...
1.go to properties of my computer 2.go to advance tab... 3. there is option to change virtual memory. 4.click on it and change virtual memory accordingly..
Hi there. The reason it's only showing 736MB is because the graphics memory is shared so it steals 256MB from the system memory. If you want a little more system memory you have to reboot the computer, enter the BIOS (press F2 on start-up) and set the shared video memory to 64 or 128MB save the changes and exit the BIOS, you will then notice when you boot into the OS your system memory will be slightly higher.
usually blue screen comes from unstable video memory or windows system or HD.
you may try
1) reinstall windows
2) change another HD to install windows
3) change new ram memory or change memories slot between one and another
if not fixed, to be sure your video memory damage which is insualted on board(separated with RAM), only the hardware repair can be fixed.
all you have to do is go into the bios, do this by pressing F2 on boot up, when in the bios you need to look for "shared memory" or "graphics memory" once you have chosen the shared memory you want save settings and exit by pressing F10, the pc will restart and the shared memory will be increased
Explain Clearly what's the problem
