Computers & Internet Logo
Anonymous Posted on Jun 02, 2012
Boot mgr is missing,also when I try to re program from o/s vista disc after installing updates ,I get the message could not prepare to boot into next stageof installation,restart installation,HELP
  • Anonymous Jun 05, 2012
    can not get into p.c even with o/s disc,I am thinking hard drive probs!!
    can only switch on or turn off.
General Systems Consulting
Level 3:
Top Expert:
  • Master 5,051 Answers
  • Posted on Jun 03, 2012
Master
Level 3:
Top Expert:
Answers
5051
Questions
0
Helped
1081122
Points
15385
You will need a operatingsystem disk or a repair disk to fix it. Insert it in the drive then bootfrom it. You want to get to a dos command prompt (black screen with whitelettering) and type the following commands. Press ENTER after eachcommand.
bootrec.exe /fixmbr
bootrec.exe /fixboot
bootrec.exe /rebuildbcd
Reboot and see if the problem is solved. If not get back to the doscommand prompt and run the check disk utility.Torun the check disk utility you will need a repair disc or a operating systemdisc. Put the disc in the cd drive and boot from it. You want toget to the Dos Command Prompt (Black screen with white letters) and type thefollowing command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
5 Related Answers
gambit3rogue
gambit3rogue
  • 106 Answers
  • Posted on May 30, 2009
SOURCE: PREINST6.SWM missing; PREINST9.SWM missing; Error:10-FC06-0002
Means pre-installion is missing. Which means yoou either have to Reinstall a fresh copy of your windows or your can reinstall your windows by just repairing the files. Its always good to make a recovery disk after every install. If you haven't tried it already restart your pc press f8 as the scene pops up and go to Last good configuration.
Anonymous
  • 255 Answers
  • Posted on Jun 21, 2009
SOURCE: Cannot Reformat Toshiba Satellite P200 using the Recovery P200
1. after recovery is done, you dont find sound on your machine
2. no problem, download the Pcwizard 2008 from the given link
save it & install it in your computer, it will give you your all
devices name and model number...
3.http://pc-wizard-2008.en.softonic.com/download#pathbar
4. note down your device name and model number and download
the drivers from the given link.
5. http://www.lostmydrivers.com/soundcard-drivers/realtek/
Note:-
If you want to Re-install your OS you can re-install and follow the above steps, hope you will solve your problems.
all the best.. try it..
Anonymous
  • 828 Answers
  • Posted on Jul 21, 2009
SOURCE: I can't boot up the Vista install on a Sony Vaio VGN-NR160E
go to your BIOS Setup, see to it that there is a Hard Disk Boot Priority, maybe you didn't put it there.
nyilasrobert
Robert Nyilas
  • 627 Answers
  • Posted on Jul 29, 2009
SOURCE: NTLDR missing issue
  1. Insert the Windows XP bootable CD into the computer.
  2. When prompted to press any key to boot from the CD, press any key.
  3. Once in the Windows XP setup menu press the "R" key to repair Windows.
  4. Log into your Windows installation by pressing the "1" key and pressing enter.
  5. You will then be prompted for your administrator password, enter that password.
  6. Copy the below two files to the root directory of the primary hard disk. In the below example we are copying these files from the CD-ROM drive letter, which in this case is "e." This letter may be different on your computer.
    copy e:\i386\ntldr c:\
    copy e:\i386\ntdetect.com c:\
  7. Once both of these files have been successfully copied, remove the CD from the computer and reboot.
Anonymous
  • Posted on Apr 10, 2010
SOURCE: BOOTMGR is missing
Bootmgr file missing
The system Post unable to proceed due to a defective Drive.
I corrected that same problem in less than 15 minute.
You are unable to boot,the error message comes up .
Bootmgr file missing ; > press ctrl alt del .
This is what I did ..I enter the BIOS I set the boot order.
(1) 1st Floppy 2nd CD ROM 3rd HDD
(2) I replace the DVD Drive with a new DVD Drive
(3) I put Gos Linux operating CD in the DVD drive
(4) I then boot the system.
(5) All went well, I format and install........
From ; mjsullkeys@hotmail.com
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
