EA Sports Cricket 07 for Windows Logo
pramod Posted on Jun 04, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
It has DINPUT.dll error - EA Sports Cricket 07 for Windows
Anonymous
Level 3:
Top Expert:
  • Master 4,961 Answers
  • Posted on Jun 04, 2012
Anonymous
Master
Level 3:
Top Expert:
Answers
4961
Questions
0
Helped
1207804
Points
16069
Dinput.dll errors usually appear when a game or other software program is started. and are caused in one way or another by an issue with Microsoft DirectX.
The dinput.dll file is one of many files contained in the DirectX software collection. Since DirectX is utilized by most Windows based games and advanced graphics programs, dinput.dll errors usually show up only when using these programs.
Solutions:
1. For Dinput.dll not found. Reinstalling Direct X should fix this.
2. Install the latest version of Microsoft DirectX. Chances are, upgrading to the latest version of DirectX will fix the dinput.dll not found error.
Note: Microsoft often releases updates to DirectX without updating the version number or letter so be sure to install the latest release even if your version is technically the same.
Note: The latest version of DirectX should be installed no matter if you're running Windows 7, Windows Vista, or Windows XP. The installation may include DirectX 11, DirectX 10, and DirectX 9 files, but they run side-by-side without problem on all of these operating systems.
3. Assuming the latest DirectX version from Microsoft doesn't fix the dinput.dll error you're receiving, look for a DirectX installation program on your game or application CD or DVD. Usually, if a game or other program utilizes DirectX, the software developers will include a copy of DirectX on the installation disc.
Sometimes, though not often, the DirectX version included on the disc is a better fit for the program than the latest version available online.
Uninstall the game or software program and then reinstall it again. Something might have happened to the program files that work with dinput.dll and a reinstall could do the trick.
Restore the dinput.dll file from the latest DirectX software package. If the above troubleshooting steps haven't worked to solve your dinput.dll error, try extracting the dinput.dll individually from the DirectX downloadable package.
4. Update the drivers for your video card. While it's not the most common solution, in some situations updating the drivers for the video card in your computer could correct this DirectX issue.
Here is a good link for DirectX info on how to download and install:
http://support.microsoft.com/kb/179113
4helpful
2answers
Mss32.dll missing on my pc
There are several different ways that mss32.dll errors can show up on your computer. Here are some of the more common ways that you might see mss32.dll errors:
  • "Mss32.dll Not Found"
  • "This application failed to start because mss32.dll was not found. Re-installing the application may fix this problem."
  • "Cannot find [PATH]\mss32.dll"
  • "The file mss32.dll is missing."
  • "Cannot start [APPLICATION]. A required component is missing: mss32.dll. Please install [APPLICATION] again."
Mss32.dll error messages might appear while using or installing certain programs, when Windows starts or shuts down, or maybe even during a Windows installation.
The context of the mss32.dll error is an important piece of information that will be helpful while solving the problem.
Cause of Mss32.dll Errors Mss32.dll errors are caused by situations that lead to the removal or corruption of the mss32.dll file.
In some cases, mss32.dll errors could indicate a registry problem, a virus or malware issue or even a hardware failure.
How to Fix Mss32.dll Errors Important: Do not download mss32.dll from a "DLL download" website. There are many reasons why downloading a DLL file is a bad idea. If you need a copy of mss32.dll, it's best to obtain it from its original, legitimate source. Note: Start Windows in Safe Mode to complete any of the following steps if you're unable to access Windows normally due to the mss32.dll error.
  1. Restore mss32.dll from the Recycle Bin: The easiest possible cause of a "missing" mss32.dll file is that you've mistakenly deleted it.
    If you suspect that you've accidentally deleted mss32.dll but you've already emptied the Recycle Bin, you may be able to recover mss32.dll with a free file recovery program.
    Important:Recovering a deleted copy of mss32.dll with a file recovery program is a smart idea only if you're confident you've deleted the file yourself and that it was working properly before you did that.
  2. Run a virus/malware scan of your entire system: Some mss32.dll errors could be related to a virus or other malware infection on your computer that has damaged the DLL file. It's even possible that the mss32.dll error you're seeing is related to a hostile program that's masquerading as the file.
  3. Use System Restore to undo recent system changes: If you suspect that the mss32.dll error was caused by a change made to an important file or configuration, a System Restore could solve the problem.
  4. Reinstall the program that uses the mss32.dll file: If the mss32.dll DLL error occurs when you use a particular program, reinstalling the program should replace the file.
    Important: Try your best to complete this step. Reinstalling the program that provides the mss32.dll file, if possible, is a likely solution to this DLL error.
  5. Update the drivers for hardware devices that might be related to mss32.dll. If, for example, you're receiving a "The file mss32.dll is missing" error when you play a 3D video game, try updating the drivers for your video card.
    Note: The mss32.dll file may or may not be related to video cards - this was just an example. The key here is to pay very close attention to the context of the error and troubleshoot accordingly.
  6. Roll back a driver to a previously installed version: if mss32.dll errors began after updating a particular hardware device's driver.
  7. Run the sfc /scannow System File Checker command: to replace a missing or corrupt copy of the mss32.dll file. If this DLL file is provided my Microsoft, the System File Checker tool should restore it.
  8. Install any available Windows updates: Many service packs and other patches replace or update some of the hundreds of Microsoft distributed DLL files on your computer. The mss32.dll file could be included in one of those updates.
  9. Test your memory and then test your hard drive: I've left the majority of hardware troubleshooting to the last step, but your computer's memory and hard drive are easy to test and are the most likely components that might cause mss32.dll errors as they fail.
    Note: If the hardware fails any of your tests, replace the memory or replace the hard drive as soon as possible.
  10. Repair your installation of Windows: If the individual mss32.dll file troubleshooting advice above is unsuccessful, performing a startup repair or repair installation should restore all Windows DLL files to their working versions.
  11. Use a free registry cleaner to repair mss32.dll related issues in the registry. A free registry cleaner program may be able to help by removing invalid mss32.dll registry entries that might be causing the DLL error.
    Important: I rarely recommend the use of registry cleaners. I've included the option here as a "last resort" attempt before the destructive step coming up next.
  12. Perform a clean installation of Windows: A clean install of Windows will erase everything from thehard driveand install a fresh copy of Windows. If none of the steps above correct the mss32.dll error, this should be your next course of action.
    Important: All the information on your hard drive will be erased during a clean install. Make sure you've made the best attempt possible to fix the mss32.dll error using a troubleshooting step prior to this one.
  13. Troubleshoot for a hardware problem if any mss32.dll errors persist. After a clean install of Windows, your DLL problem can only be hardware related.
Applies To The mss32.dll error message could apply to any program or system that might utilize the file on any of Microsoft's operating systems including Windows 7, Windows Vista, Windows XP, and Windows 2000.
Still Having Mss32.dll Issues? Let a community of computer support enthusiasts help out! Post the details of your mss32.dll issue in the PC Support Forum. Be sure to let us know the exact mss32.dll error message that you're seeing and what steps, if any, you've already taken to fix the problem.
Theres A Problem of My Computer How To Fix MY Computer The Eror Name is iertutil.dll Thats My Problem Eror
This error message means that the program with iertutil.dll file which you want to run is corrupted. The iertutil.dll file is invalis, corrupted or missing. You can try to download the iertutil.dll file online yourself and then locatr it to the certain folder. And you can try to uninstall and reinstall the application which gives you the error message. Moreover, if you want to fix and avoid dll errors throughly, you should regularly clean and fix the Windows registry errors.
2helpful
2answers
Hi i keep getting error messages containing d3d9.dll and d3d10.dll
http://www.fix-all-dll-errors.com/d3d9.dll/
http://www.fix-all-dll-errors.com/d3d10.dll/
Your faulty d3d9.dll & d3d10.dll can be repaired here...so just go to the link given above.
This will register the dll files on your system.
2helpful
2answers
Clkern.dll was loaded,but the dll register server entry point was not found.this file can not be registered
http://www.fix-all-dll-errors.com/clkern.dll/
Once you go to the above link click "Fix dll errors now" button,
it will register the dll file for you.
10helpful
3answers
How to install msvcp90.dll
hi,
http://www.fix-all-dll-errors.com/msvcp90.dll/
u can go to this site...this will help in case of missing or for downloading dll's or also if there is errors in dll's..!
I also registered few dll's from this site...worked in my case :)
1helpful
2answers
My problem is I have a printer and I cannot install it because the file wiafdrv.dll on windowsxp home editon cd-rom is needed an do not have one.
Do you have a Lexmark printer? I found this dll file and many of the comments about it relate to Lexmark printer issues. Click the below link and it will download your missing dll file. I searched for "wiafdrv.dll" and there were no hits for this dll, but there was one for the dll file "wiafbdrv.dll". Make sure before clicking the link below, that this is the correctly named dll file you need.
http://www.dll-files.com/dllindex/wiafbdrv.zip?0VFiP0aMgO
Extract this file and place the dll file in the correct location as specified by the error you're receiving.
2answers
Dll file have error
Hi alexistech, the wininet.dll & newdev.dll are windows fies. You can try this link to fix your *.dll files.
http://www.dll-files.com/dllindex/dll-files.shtml?normaliz
Luck!
If this helps, please let me know.
Need more help just post your questions here.
Mike
4helpful
3answers
Trouble with slbcsp.dll and sccbase.dll
http://www.fix-all-dll-errors.com/slbcsp.dll/
http://www.fix-all-dll-errors.com/sccbase.dll/
This is the best place to get dll problems solved.
Just follow the link given above and click the button "Fix dll errors now" and you are through.
9helpful
5answers
Prison tycoon 3
hi,
http://www.fix-all-dll-errors.com/d3dx9_25.dll/
u can go to this site...this will help in case of missing or download dll's or errors in dll's..!!
Top EA Sports Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Tim Hofstetter
Tim Hofstetter
Are you an EA Sports Video Game Console and Game Expert? Answer questions, earn points and help others
