Proform Crosswalk 500 Treadmill Logo
guy wilson Posted on Jun 09, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Motor controller adjustments - Proform Crosswalk 500 Treadmill
ernesto cuadra
Level 3:
Top Expert:
  • Proform Master 12,223 Answers
  • Posted on Jun 09, 2012
ernesto cuadra
Proform Master
Level 3:
Top Expert:
Answers
12223
Questions
0
Helped
4176552
Points
34435
Go to www.doctotreamill.com and look how to adjust it.
God bless you
What is eap rely on a 2004 Chevy trailblazer
adjustable pedal relay Adjustable Pedals System Components
The adjustable pedals system consists of the following components:
• The adjustable pedals position switch
• The driver seat module
• The adjustable pedals relay
• The adjustable pedals motor
• The brake pedal position sensor
Adjustable Pedals System Operation
The adjustable pedal system is controlled by the adjustable pedal switch or the driver seat module and operation can occur only while the transmission selector lever is in the PARK position. The adjustable pedal assembly is moved forward or backward by a motor, which is fixed to the brake pedal actuator with a drive cable to the accelerator pedal actuator. The adjustable pedal motor is operated by 2 motor control circuits from the adjustable pedal relay. In an inactive state, both of the motor control circuits are closed to the ground contacts within the relay. The relay coils may be energized by the relay control circuits from the driver seat module or the adjustable pedal switch. When a relay coil is energized, the motor control circuit is switched to the battery voltage supply contact. The adjuster motor is bi-directional and the direction of the pedal assembly travel is determined by which of the motor control circuits is closed to battery voltage, while the other remains grounded.
The driver seat module monitors the location of the adjustable pedals using the brake pedal position sensor. The brake pedal position sensor is supplied with 5-volt reference and ground circuits from the driver seat module. The position sensor signal circuit is referenced from ground within the driver seat module. The signal voltage monitored by the driver seat module ranges from 0.39-4.58 volts and is determined by the wiper location on the resistor within the position sensor. The position sensor circuit voltage level is used by the driver seat module to determine the position of the adjustable pedals when storing or recalling memory position settings.
The front seats for our 2003 Escalade will not move forward or backward and the heat control for the front seats will not work.
Does your Escalade have memory seats ?
There are 2 options of power seat systems available in full size trucks. The 6 way driver and passenger power seats, and 8 way driver and passenger power seats with driver memory. For the driver memory seat operation refer to Memory Seats Description and Operation . Power seats without memory are completely controlled through the power seat switch. Battery voltage is supplied to the power seat switch through the power seat circuit breaker. While the seat adjuster switches are in an inactive state the switch contacts are closed to the power seat switch ground circuit. When a power seat switch is pressed to an active state the switch contact is closed to the battery voltage supply circuit. Each seat adjuster motor is controlled by the power seat switch through 2 motor control circuits. The seat adjuster motors are bidirectional and the direction of adjuster motor rotation is determined by which of the adjuster motor control circuits is switched to battery voltage while the other remains grounded.
Wing mirrors will not adjust
Hi Michelle , what make model an year vehicle ? On some vehicles this is function is controlled by a door module .
In order to control outside rearview mirror operations, as well as other door functions, the front door modules must be powered up. For this purpose, battery voltage is supplied from the rear fuse block, through separate circuits, to each front door module. Each front door module is separately grounded through a ground stake. The front door modules also use these power and ground supplies to drive the mirror motors, and to provide power and ground to window and lock switches and door lock actuators. In addition, the driver door module (DDM) uses these power and ground supplies to power the driver door switch assembly (DDSA) and integral mirror control switches.
Could have DTC'S - diagnostic trouble codes stored in BCM - body control module .
DTC B1544 01: Mirror Motors Common Circuit Short to Voltage
DTC B1544 02: Mirror Motors Common Circuit Short to Ground
DTC B1544 04: Mirror Motors Common Circuit Open Circuit
DTC B1600 01: Mirror Motor 1 (vertical) Circuit Short to Voltage
DTC B1600 02: Mirror Motor 1 (vertical) Circuit Short to Ground
DTC B1600 04: Mirror Motor 1 (vertical) Circuit Open Circuit
DTC B1605 01: Mirror Motor 2 (horizontal) Circuit Short to Voltage
DTC B1605 02: Mirror Motor 2 (horizontal) Circuit Short to Ground
DTC B1605 04: Mirror Motor 2 (horizontal) Circuit Open Circuit .
How do you adjust the carburetor on my 83 buick regal limited 4.1L-v6
There should be an idle control motor on the side of the carb. The computer controls idle speed by moving the stop on that control motor. The stop is adjustable and there may also be a base idle adjusting screw near the control motor.
94 nissan altima won't start and iddle after cleaning IACV valve
An IAC (idle air control) motor is designed to adjust the engine idle RPM speed by opening and closing an air bypass passage inside the throttle body. The cars computer or PCM (powertrain control module) receives information from various sensors and will output signals to adjust the idle air control motor in or out to adjust engine idle speed by controlling engine idle air. An idle air control motor can fail one of two ways, either the motor short circuits and stops working or the motor will develop high resistance and cause the idle air control motor to react slowly, either failure can cause the engine to stall at idle. When a trouble code scan is performed it sometimes won't always detect a failed or weak idle air control motor.
5helpful
Just started idling rough, sometimes stalling
Shot in the dark here without knowing the vehicle but it could be an Idle Air Control valve starting to fail. An IAC (idle air control) motor is designed to adjust the engine idle RPM speed by opening and closing an air bypass passage inside the throttle body. The cars computer or PCM (powertrain control module) receives information from various sensors and will output signals to adjust the idle air control motor in or out to adjust engine idle speed by controlling engine idle air. An idle air control motor can fail one of two ways, either the motor short circuits and stops working or the motor will develop high resistance and cause the idle air control motor to react slowly, either failure can cause the engine to stall at idle. When a trouble code scan is performed it sometimes won't always detect a failed or weak idle air control motor. To check the idle air control motor remove the unit, with the wires connected turn the key to the "on" position without starting the engine, the idle air control should move in or out. If the idle air control motor does nothing it has probably failed, replace it with a new unit and recheck system. Note: while the idle air control motor is removed clean (use aerosol carburetor cleaner) the passages the idle air control uses to control idle air speed, also inspect the idle air control for a build-up on the seating (pointed) end and clean as necessary.
The six way power seat on my 2005 suburban has an issue. When I turn the motor off and remove the key the motor goes to it's down and back position but continues to run. And it doesn't respond to the...
The first place to start would be to have the dealer or someother qualified repair shop , that has a professional scan tool read DTC'S - diagnostic trouble codes in the driver seat module ! The seat adjuster motors are controlled by the driver seat module through the adjuster motor control circuits. In an inactive state both of the motor control circuits are grounded within the driver seat module. In an active state the driver seat module switches the appropriate motor control circuit to battery positive voltage. The direction of the adjuster motor rotation is determined by which of the motor control circuits is switched to battery positive voltage while the other remains grounded. During adjuster motor operation the driver seat module also monitors the current flow through the motor control circuits.
DTC B1770, B1775, B1780, B1785, B1790, B1805, or B2415
B1825 , B1850, B1860, B1960, B2355, B2365, or B2375
B3962
Memory Seat System Components
The memory seat system consists of the following components:
• Power seat switch assembly
• Memory recall switch assembly
• Horizontal adjuster motor
• Front vertical adjuster motor
• Rear vertical adjuster motor
• Recline adjuster motor
• Driver seat module
• Driver door module
• SEAT 30A circuit breaker
Memory Seat System Description
Battery voltage is supplied to the driver seat module through the power seat circuit breaker. The driver seat module supplies the seat adjuster switch assembly with a battery positive reference voltage. While the seat adjuster switches are in an inactive state the switch contacts are closed to the adjuster switch ground circuit. When a seat adjuster switch is pressed to an active state the switch contact is closed to the reference voltage circuit. Battery voltage on a switch signal circuit indicates to the driver seat module the switch status is active. Each seat adjuster motor is controlled by the driver seat module through 2 motor control circuits. While the seat adjuster motors are in an inactive state the motor control circuits are closed to ground circuit contacts within the driver seat module. The driver seat module operates the seat adjuster motors by switching one of a motor's control circuits to battery voltage. The seat adjuster motors are bidirectional and the direction of adjuster motor rotation is determined by which of the adjuster motor control circuits is switched to battery voltage while the other remains grounded.
Memory Set/Recall Operation
The seat adjuster motors are equipped with internal position sensors. The adjuster motor position sensors are monitored by the driver seat module and are used to determine the seat position when storing or recalling memory settings. The horizontal, front vertical, and rear vertical adjuster motors use hall effect type position sensors. The hall effect position sensors are supplied with battery positive reference and ground circuits from the driver seat module. The position sensor signal circuits are supplied battery positive voltage through a resistor them monitored within the driver seat module. During adjuster motor operation the hall effect position sensor provides a single pulse for every revolution of the adjuster motor shaft. The driver seat module counts the pulses from the position sensor signal circuits to determine the adjuster motor positions when storing or recalling memory seat position settings. The recline adjuster motor is equipped with a potentiometer type position sensor. The recline motor position sensor is supplied with it's own 5-volt reference ground circuits from the driver seat module. The recline position sensor signal circuit is referenced from ground within the driver seat module. The signal voltage monitored by the driver seat module ranges from 0.39 - 4.58 volts and is determined by the wiper location on the resistor within the recline motor position sensor. The recline motor position sensor signal circuit voltage level is used by the driver seat module to determine the seat recline position when storing or recalling memory seat position settings.
The memory recall switch assembly on the driver's door provides inputs to the driver door module. Battery voltage is supplied to the memory
3answers
Idle at 250 rpm
Idle Speed Control (ISC) Motor OPERATION Eagle Throttle Body Fuel Injection (TBI) System NOTE: The Eagle TBI system is used only on 2.5L Premier engines. The Idle Speed Control (ISC) motor is mounted to the throttle body and controlled by the PCM. The throttle lever rests against the initial adjustment screw of the actuator (plunger). The idle speed is not adjustable. The initial adjustment screw is only used to establish the initial positioning of the actuator when the ISC motor has been replaced. The actuator extends or retracts to control engine idle speed and to set throttle stop angle during deceleration. Based on inputs from the various engine control system sensors and switches to the PCM supplies current to the ISC motor to adjust the actuator position for the particular operating conditions.
Replaced the motor controls
Is there a sheet of paper under the motor hood? It has the procedures for this calibration of the motor speed. Caution ! You should use a plastic screwdriver to make adjustment to the speed control on the motor controller. It is high voltage
Top Proform Exercise & Fitness Experts
Grand Canyon Tech
Grand Canyon Tech
john h
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
