RTO Aviva Crazy Twister Noodle Water Pool Lake Float Raft Logo
Anonymous Posted on Dec 01, 2008
How does it work
How do inflatable rafts work?
Anonymous
Level 3:
President:
  • Master 2,712 Answers
  • Posted on Dec 01, 2008
Anonymous
Master
Level 3:
President:
Answers
2712
Questions
Helped
742646
Points
8771
In all cases, there is a small, factory-manufactured cylinder of highly compressed gas (usually CO2) with a mechanism on it that perforates a given area when actuated -- for example, by pulling a 'string' or by the action of opening a depressurised aircraft door. A parallel would be tripping the plate on a mousetrap -- all that gas is busting to get out, and when its weak point is compromised, that's exactly what happens. In other words, when the cylinder of gas gets a hole punched into it in the right place, the gas inside floods out -- usually into a big plastic bag in the shape of an inflatable raft or vest. Think of it as, all the air that could fill a big balloon, but wedged into something the size of a medical capsule. Pop the capsule, the balloon fills up. Except it's not air, and it's not a balloon.
1helpful
Intex challenger 400 parts
Contact Inflatable boat specialist. There is one that I know of in ventura california. Contact them first and go from there. 3695 East Harbor Boulevard Ventura, CA 93001
(805) 644-6290
I have a SeaHawk 340 that is missing the cap for the main air chamber. therefore, I can neither inflate it and hold in the air if it was inflated. Is there any chance of a replacement part?
Too late with this reply, but hope it helps someone else like us. I had the same problem, then discovered the boat manual and found the cap is called a Boston valve; in this case 2cm (diameter). I cannibalised a smaller boat of ours for one (valve the same size), and you may get one cheaply by doing the same from a cheap boat at a car boot sale. Otherwise search eBay or Amazon for "Boston valve" or "Boston screw"; not cheap, but still a lot cheaper than a new boat.
How well does the Fish Hunter 280 do in the Ocean?
I don't think it would do well at all, Ive taken my Fishhunter 360 in larger lakes with waves and came close to tipping quite a few times with all the gear, motor,etc. Try an inflatable with a v-hull if the oceans your thing!
The tube around my intex pool has a leak, how do I find it and fix it?
Your picture above is of a pool float, but I assume you are talking about an inflatable ring pool. Is that right? If so, this link will take you through a tutorial on how to find and repair pool leaks:
http://www.backyardcitypools.com/vinyl-pool-liners/Swimming-Pool-Leaks.htm
Have a leak in my tube in my super mable inflatable raft
Use Sevylor Seam Seal...liquid gold it will fix it try www.twister.com.au they sell it!
I need my inflatable raft repaired i live in new york city where can i go to get it fixed.
You can actually save a BUNCH of money and do it your self its really easy go to a sporting good store or online and look for a raft repair kit takes a couple hours including dry time and costs less than 20 bucks
Save your life?
Absolutely. All sailing and sea-going craft should carry rafts - inflatable vessels which can maintain the lives of stricken mariners until rescue is available.
1helpful
Bought a newwprosport fitness ball from Target. no instructions
You just use a pump with a pointy nozzle, even an air compressor with the tip for inflating rafts and inflatables. You should fill it with enough air so that it is firm when you sit on it, but it should still have about 2" of give. (knee's @ a 90 degree angle when sitting on the ball). Hope this helps!
Top RTO Boating Experts
ADMIN Andrew
ADMIN Andrew
Kardoc
john h
Are you a RTO Boating Expert? Answer questions, earn points and help others
