SOURCE: Bushnell night vision binoculars
They do stay on for a while after switch, that is OK. Dim and out of focus may indicate that the output voltage is low. If replacing the battery does not fix it, then the problem may be in the power supply circuit.
SOURCE: Newcon Optik Night Vision Binoculars BN5
The lenses screw out, the electronics are in the body and this involves removing all the screws, including the ones behing the rubber casing. Why do you wish to strip them out?
SOURCE: tasco nv 356 night binoculars
Check the HV to the tube and see if you can see any discolouration or spots on the tube - they often indicate tube failure. Many binoculars use the one power supply for both tubes as the current demand is very low. Often, one tube operation indicates tube failure, but a wire or connection could be at fault.
SOURCE: need battery
Check with; www.rugift.com they sell these russian NV and will probably have the batts or have a source. Good luck. :)
SOURCE: I have a cyclops-1 russian
This is by design. You can replace it with a toggle switch from radio shack. You will need to know how to solder.
