SOURCE: HP Officejet 5610 All-in-one printing in red instead of black!
Hi ,
As you have already tried replacing the ink cartridge , u can try to reset the printer .
Perform a semi-full reset on the all-in-one by following the steps below
Take out the cartridges from the unit .
Make sure the unit is connected to the wall jack directly without any surge protector.
Unplug the power cord from the back of the unit ( without turning off the unit ) .
Now press the # and 6 key together , while holding these keys down plug in the power cord back into the unit .
5
Do not release the keys after a few seconds u will find te hp logo or bars moving across the screen .wait while the unit turns off.
6
after one minute turn on the prnter . it will go into alligment phase > let it finish .
7
after its done > try to make a copy .
8 Allow the all-in-one to re-initialize. This may take a minute or two.
9 If prompts appear in the all-in-one display to set the front panel language and country settings, perform the steps to set this information
Note - you can also try the Ok n cancel key combination in place of # and 6 .in case the first combination does not work .
Thanks
SOURCE: faded print
IT TURNED OUT TO BE A FAULTY WORN DOWN BLACK CARTRIGE!
WE REPLACED IT,AND THE PRINTER IS WORKING FINE.
THANKS,
DURANGO21
SOURCE: Error message "remove and check black cartridge"
Buy a new HP cartridge, 3rd party cartidges for HP machines have substantially lower reliability
SOURCE: hp officejet 7310 won't print in black
You people are stupid! After the first person detailed the problem, why do you reiterate by saying "me too, me too"? People come here looking for answers, not more of the same. Here's a suggestion. If you don't have a solution, don't say anything!!!
SOURCE: I have a HP Officejet
Hi The no of parts that hp supply is small but the best place to see if hp supply this as a part is a site www.partsurfer.hp.com this will get the part no then google the part no to get a price I hope this is a help Yours Ian
