Royal Alpha 9500ml Cash Register Logo
Anonymous Posted on Jul 21, 2012
Program a tax table - Royal Alpha 9500ml Cash Register
beneshkumar chalappuram
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 28, 2014
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
266
Points
OUR SYSTEM INFO
ZONTALK TID:00024495
OS VERSION :QJ0012AO
APPL VERS:2.09
RAM SIZE :2048
FLASH SIZE :4096
AVAIL RAM :1231300
SERIAL NO:214-825-406
PTID :28580696
PART NO :M25152936EUC
APPL SIZE :567140
APPL DATE :22/12/2011 09:51:48
SDK VER:3.5.0
UCL VER:2.21.1
TCP/IP VER :4.21.0
EMV VER :ver 5.0.6
MODEL NO :V510G
CREDIT CARD
TERMINAL ID :00024495
MERCHANT ID :960692000
BATCH :693
D/N DATE 27/6/2014 22:41
DATE 28/6/2014 13:15:20
Just recently bought a Casio PCR-T500 and is there any way I can use it without having to program any departments or PLUs?
Look through the tables in PLU programming and there will be a setting to link a department number to the PLU. Link it to the department you set the tax on and it will use that tax setting.
Casio pcr 308 cash register
Per the instructions on the Casio4Business Support website, you can do the following:
PCR 308, 350, 355, 408, 450
TO PROGRAM STATUS OF DEPARTMENT KEYS:
1. TURN KEY TO Z MODE
2. PRESS SUBTOTAL
3. PRESS 02 FOR TAX TABLE 1, 04 FOR TAX TABLE 2, 06 FOR BOTH TAX TABLES, AND 00 FOR NO TAX
4. PRESS DEPARTMENT KEY
5. REPEAT STEPS 3 & 4 FOR MULTIPLE DEPTS.
6. PRESS SUBTOTAL
You can access additional information at the main support site: http://www.casio4business.com/sa/support/taxtable_programming.html
Regards!
2answers
Tax Rate Button
That is the correct program it seems your program is corrupt, just wipe out everything and start afresh
2answers
How do i set the tax rate for Casio QT-6600?
go to PGM 3 then go to
1- Machine Feature
go to
9-Tax Table
go to
1- tax table 1
set tax rate to 5.0000
set Rounding to Round up
set singapore Rounding to Round up if you are not using the 1 cent anymore
set calculation Type to Table and Add on
Press ESC to go back to Tax Table window and choose
2- Tax Table 2
repeat the same steps as for Tax Table 1 but set the tax rate to 9.98
How to program two non cumulative taxes on a Casio PCR-T2000A?
Firstly, change the rates for each tax in the tax rate setting tables of your manual. Then you need to turn on tax rate 1 and 2 for departments that need both. This is done in the department programming tables. Tax setting can be quite involved so follow the tables carefully.If you need a programming manual, One of the users has it here:
http://the-checkout-tech.com/manuals/cashregisters/Casio_PCR-T2000_users_and_programming_manual.html
Sharp cash register xe a41s tax programming
The two main programs to edit are the tax rate program and the department program. have a look at these tables in the manual and set your tax.
If you need an XE-A41S manual, there is one here:
http://the-checkout-tech.com/manuals/cashregisters/Sharp_XE-A41S_programming_manual.html
How do I rename a tax table on my Casio PCR-T2000? I am interested in changing all my registers to the Ontario HST of 13%. Thanks very much.
Use the PGM key and set to PGM. 3, sub total, enter tax table {1, 2, 3, 4}, Tax PGM, 13.00, ca/amt tend, skip to set 'round off/add-on', ca/amt tend, sub total. 4 tax tables are used for the following purposes: table 1 for the federal tax items, table 2 for the provincial tax, 3 and 4 for provincial and different tax table.
I need to know how to program a new tax rate
move the pgm key to pgm mode 3 subtotal 125 subtotal ( tax table) rate tax and subtotal beginning  level tax ejemplo : for ten cent = 10  and subtotal 5002 subtotal subtotal.
to applay the tax to dept or plu
move the pgm key to pgm mode 3 subtotal 366 subtotal 1 and all dept o plu  subtotal
4helpful
3answers
Casio tk1300
I'm in Australia and only going on the program manual for your area, it states that canadian tax is tax on tax? if this is true then you probably entered a code for add on or add in tax and thereby changed it all.
you need the following
tax table address
1 125
2 225
3 325
4 425
rounding off codes
rounding off to 2 decimal places is 50
rounding up to 2 decimal places is 90
cut off to 2 decimal places is 00
tax system code
tax table with out tax rate 01
tax table with tax rate and add on rate 02
add in tax rate 03
Canadian tax-on-tax rate 04
starting point
to get the starting point you multiply by 100 and subtract 1
eg 50 cents = 0.50 X 100 - 1 = 50 - 1 = 49
eg $4 = 4.00 x 100 -1 = 399
to program the tables go through these steps
go to program 3
tax table address eg 125
subtotal
tax rate
ca/amt tend
starting point eg 0.50 = 49
ca/amt tend
rounding eg 50
tax system eg 04
ca/amt tend
ca/amt tend
here you have 2 choices,
press ca/amt tend to go to the next tax table ie 225 and start over by entering the tax rate and go through the procedure again
or
press subtotal to finalise the tax table you are on
Hope this helps,
Adam
Top Royal Retail Supplies Experts
ADMIN Andrew
ADMIN Andrew
Don A
Don A
Patrick Tinashe...
Are you a Royal Retail Supply Expert? Answer questions, earn points and help others
