AEG Djazy 7215 1Line Cordless Phone Logo
djama electech Posted on Jul 26, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Problem charge i9000 galaxy samsung
Computer Repairing
Level 3:
  • AEG Master 14,641 Answers
  • Posted on Jul 27, 2012
Computer Repairing
AEG Master
Level 3:
Answers
14641
Questions
0
Helped
733116
Points
53083
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Where can i get my galaxy s charging port fixed and how would the port become loose?
If it's loose it is probably broken away from the internal circuit board. A common problem. People accidentally knock the plug sideways and they only have fragile connections.
Get a technician to resolver if possible or take to Samsung repair centre.
tip
How to hard reset samsung I9000 galaxy S
To <span>Hard</span> <span>Reset</span> Samsung I9000 Galaxy S<br /> 1. Turn the power off. If your Samsung Galaxy S is frozen, pull the battery out and <br /> reinsert it<br /> 2. Hold the Volume Down button<br /> 3. Press and release the Power button<br /> 4. You are now presented with a menu that allows for Fastbook, Recovery, Clear Storage, <br /> and Simlock<br /> 5. Select Clear Storage by pressing the Volume Down button<br /> 6. Press and release the Power button<br /> 7. Now simply confirm your decision: Volume Up for YES and Volume Down for NO<br /> <br /> If the above procedures doesn't work, use this second method below,<br /> 1. Shut Down Samsung I9000 Galaxy S<br /> 2. Now press the Volume up, Home and Power button together.<br /> 3. When Samsung Symbol shows up release the power.<br /> 4. Then there is a boot Menu. Use the volume up/down to choose and home to select.<br /> If YES is selected, all data including third-party applications will be deleted from your <br /> Samsung I9000 Galaxy S. Once the wipe is complete, the phone will reboot to its factory <br /> fresh state.
on Feb 12, 2011 • Cell Phones
Vodafone network unlock
To unlock your Samsung Galaxy S GT-I9000 from Vodafone Network ,you can use Unlock code. You can get the unlock code from MobileUnlockSolutions.com . There you have to give your Country and current network name along with your IMEI number to get the unlock code. They will give you the unlock code along with instruction on how to unlock. Follow the instruction correctly and unlock your Samsung Galaxy S GT-I9000 .
Samsung galaxy s not charging
First Option:
Second Option:
1helpful
Where do you enter the unlock code in the samsung phone
You can Enter the Unlock code in Samsung Galaxy S I9000 using the Unlocking instructions below: You can get the Unlocking instructions at here Wickedunlock.com/samsung-i9000-galaxy-s/rs11wp9/ at free of cost.
Samsung I9000 Galaxy S Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Samsung I9000 Galaxy S mobile phones. If you enter over a certain amount of wrong unlock codes on your Samsung I9000 Galaxy S mobile phone, your phone may get hard locked and sometimes become unusable.
Method 1:
1 - Switch ON your Samsung I9000 Galaxy S with a NOT ACCEPTED SIM Card.
2 - Samsung I9000 Galaxy S will ask for "Password".
3 - Enter the Unlock Code.
OR (if the Samsung I9000 Galaxy S shows "Insert Correct SIM Card")
Method 2:
2 - Don't bother about what's being displayed on your Samsung I9000 Galaxy S.
3 - Compose : #0111*CODE#.
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Samsung I9000 Galaxy S is locked to.
CODE: Its the unique Unlock Code for your Samsung I9000 Galaxy S.
If method 2 does not work, you can try method 2 again but this time without any SIM card on your Samsung I9000 Galaxy S.
Hi can i get a free unlock code for my galaxy s
Free Unlock code can be get for the OLD SAMSUNG,DCT Nokia Phones,But this is Latest PDA Phones,You need to pay for this Model,Get the paid Unlock code from here Onlinegsmunlock and Unlock it safe and secure using the Instructions Below..
Samsung I9000 Galaxy S Unlocking Instructions Warning : Do not enter any wrong unlock codes on your Samsung I9000 Galaxy S mobile phones. If you enter over a certain amount of wrong unlock codes on your Samsung I9000 Galaxy S mobile phone, your phone may get hard locked and sometimes become unusable.
Method 1:
Method 2:
4helpful
2answers
I cannot remember my unlock pattern on my GT-I9000
You can try about the master reset system. Caution: All of your data will be lost that means your sms, notes, calender contact no.
please follow the instructions.
Samsung GT-i9000 Galaxy S hard reset
1. Turn off the i9000 phone or take out the battery and reinsert it.
4. Select Clear Storage by pressing the Volume Down button
5. Press and release the Power button
6. Press Volume Up to confirm i9000 master reset
Please watch this video clips for unlock your Samsung Galaxy Phone. This may be helpful for you.
http://www.unlockedgsmquad.com/unlocked-samsung-galaxy-s-gt-i9000-feature-tour/
If you can't the consult with a professional technician who unlock your phone by using flash box tools. thank you so much.
2answers
Found phone and need to unlock code
To Unlock Samsung Galaxy I9000 S model mobile Reach here
http://www.mobileunlocksolutions.com/samsung-i9000-galaxy-s/rs1wp9/ buy the Unlock Code and Unlock it.
Top AEG Lands Phones Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an AEG Lands Phone Expert? Answer questions, earn points and help others
