A
Anonymous Posted on Aug 07, 2012
How to reset the fuser error ( error code sc 542)
3 Related Answers
Anonymous
  • 71 Answers
  • Posted on Aug 14, 2007
SOURCE: sc 542 error code
Error SC 542 indicates a fuser temperature problem. Once the error is detected, the printer is toast until you manually clear the error from the keypad. Even though the printer is physically fine, it won?t come ready until the prior error condition is cleared. The magic keystrokes, clear the error code: The Fix In order to clear error SC542, you must perform procedure 5810. Press and hold online + escape, then power on. Use up and down arrow keys to select SP2 Press Enter Use up and down arror to locate SP5 Press Enter Use up and down arrow keys to select 810 Press Enter Confirm the selection Power off and on. The error code is now cleared.
Anonymous
  • 86 Answers
  • Posted on Jan 17, 2009
SOURCE: Ricoh Aficio MP 2510 SC 541, SC 542 Errors
To clear level A SC codes such as this SC541, you need to
Enter SP mode, and then turn the main power switch off and on, only.
Please check if the thermistors are the proper ones and are installed correctly in their position properly.
This is also useful for SC542.
Please check the thermostats and fusing lamps for open circuit.
Good luck and please rate me, thanks.
Anonymous
  • 183 Answers
  • Posted on Mar 26, 2011
SOURCE: How to reset the fuser
press yellow cancel and 107 and hold on 5 sconds on red cancel and yo will see 1 go to 4 and select 810 and press 1 simultanously with photo press you will see reset accepted or succes
Top Ricoh Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
