Honda Eu6500is Eu6500 Generator Service Repair Manual 61z2500e4 Logo
mark young Posted on Aug 12, 2012
What does error code e04 mean - Honda Eu6500is Eu6500 Generator Service Repair Manual 61z2500e4
Darren
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 1 Answer
  • Posted on Jan 12, 2013
Darren
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
Questions
Helped
2346
Points
E 04 means thereis a problem with the govener circut
What is error code e04 bosch front loader washer
The "E04" error code on your Bosch washer refers to a drainage problem as you may or may not already know. ( it can mean door lock error, but that is usually a by-product of it not draining )
What you may have is either a partially clogged pump, or a faulty pump...the later being the least likely
What does fault code e04 mean
There are many brands of washers and the error codes are different.
What kind of washer do you have. Brand name and model number.
Open door and look around the frame for the model number.
Here is a link to e04 on a Bosch washer.
Repairing 04 Error on Bosch Washer
1helpful
2answers
I have an electrolux w3180 error code e04 comes upon starting a program. In the manual it states Temperature sensing device indicates temperature below -5°C (continuity fault). Is this just loose...
Hello, The "e04" error code means is an indication of a water temperature sensor error below 04'c
what it means is that there is over flow of water in the sensor reader around the wire and the sensor
what you have to do to fix up the problem is to unscrew (open)the washer then cleanup the water around and also the dirt sensor and wire and allow it to relax for some time after clean up
please the clean up DOES NOT NEED water or any form of liquid to do this just apply dry cloth for the cleaning.
Thanks
1helpful
Danby dpac120068 blue light flashing with error code E04 and the compressor keeps turning off randomly. What is causing this? What does E04 mean?
E04 refers to Overheating. There might be plenty of reasons. You might have seen, if you shut down the ac for few minutes and again start it, It would work for few minutes and the same E04 display is there.
This is tech's job. I am sorry, i am not discouraging you but it requires certain testing that actually what makes ac overheated.
This is dangerous. So, better to call a tech and get it checked!!
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
1helpful
2answers
Dp-2010e code e04-01
E 4-01 is a fuser error that only can be reset in service mode F9 reset fuser
14helpful
2answers
Machine error E04-01
error e04-01 means fuser warm up temperature
problems could be
-fuser thermister dirty ir defective
-fuser lamp is disconnected or defective
-fuser thermostat is defective
1helpful
2answers
E04 message
Lisa, E04 is an error code which shows that one or both of the reels has stopped during play or record operation. We find that tapes with liquid contamination can stick to internal parts in the mechanism causing this error. Try another tape, if this does not resolve the problem something is defective in the tape transport. Good Luck to you! Joe Weibel customelectronics.org
Top Honda Electronics - Others Experts
ADMIN Andrew
ADMIN Andrew
Larry Ng
Larry Ng
Are you a Honda Electronics - Other Expert? Answer questions, earn points and help others
