Samsung DMT800RHS Dishwasher Logo
Chris Posted on Sep 01, 2012
OE error code
I am writing with a possible resolution to an oE (over level water) error code. The manual suggests shutting off water and power and contacting a service tech should you get the error. I got the error a month after the 1-year warranty ran out. I looked around but couldn't find much in the way of a solution for this model. I removed the interior drain assembly and cleand it thoroughly. It was disgusting. I reassembly and re-installed it. I was able to run the dishwasher through one cycle, but got the oE error on the second attempt. It took the drain assembly apart and cleaned it again with the same result. I finally removed the dishwasher from under the counter and found the float and sensor for the water level. I revoved this assembly and cleaned it thoroughly. I used wire brushes, pipe cleaners, and drain cleaner to clear the clogs. I also cleaned the tubes that connect to this assembly. They were rather plugged as well. I reassembled the unit and it is running fine now. I am going to attempt to run the sanatize program more often and make sure that we don't leave dirty dishes in the washer for extended periods of time. Hope this helps.
5 Related Answers
Anonymous
  • 3 Answers
  • Posted on Feb 06, 2012
SOURCE: I have a DMT300rfw samsung dishwasher. The other
I just had this same problem, and I think I figured it out. There was water on the bottom from the last cycle, so I pressed HEAVY and DELICATE at the same time for 3 seconds (you'll see it printed on the control panel), and the unit drained. I was then able to start the new cycle normally without the error. Hope that helps!
Anonymous
  • 4323 Answers
  • Posted on Aug 24, 2011
SOURCE: My DMR78AHS dishwasher stopped washing. It runs
Hi
If the water inlet valve is fine and it fills with water then the issue seems to be with the float switch assembly that is bad and should be replaced. Float assembly is found inside the dishwasher's tub, on the bottom. The water that fills the dishwasher lifts the float, and when it reaches a certain level, it acts as a trigger for the float switch. The float triggers the float switch to shut off, thereby shutting off the flow of water into the dishwasher. A defective switch may interfere with dishwasher's filling and/or draining ability. Use voltmeter to test the switch. Set the device to the ohms setting x 1. Take each probe and touch them to one switch terminal each. This should produce a reading of either zero or infinity. Continue to touch the probes to the terminals, and press down on the switch's button. The reading should change to the opposite extreme. If the switch fails either of these tests, you should replace it. Hope this helps...please post back for further assistance.
Daniel
mc1bean
Mike Cairns
  • 3054 Answers
  • Posted on Oct 27, 2011
Hello, jduffy
I was trying to help you out here. I was going back to some customers that asked questions in the past and it appeared that no one answered them, so I thought I would take some of my personal time to see if I can help. Even though this site may not have your exact model or brand, This link will help you tons. Here is a link to about everything you want to know about your dishwasher, from repair to trouble shooting it,pictures, video's. Just scroll around and you will see tons of information to almost any question you might have on your dishwasher. If you go to this link and click around, I am sure you will find out so much about your dishwasher, you will know more that the company that made it. Here Is the link for you to click on>>
http://home.howstuffworks.com/dishwasher.htm
Please if this helped you at all, if you can find the time to rate my help and some kind words written would be appreciated for my free help , I would appreciate it. Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks,Mike
http://beta.fixya.com/users/mc1bean
Anonymous
  • 539 Answers
  • Posted on Apr 11, 2012
SOURCE: samsung dishwasher crackling popping sound
Try http://www.manualowl.com
for FREE PDF and perhaps you can troubleshoot problem yourself.
Best of luck with your frustrating issue. I empathize, shampayn20.Jimmy
Testimonial: "Thank you. I will try this and see what happens. I'm running out of patience with this particular appliance :)"
Anonymous
  • Posted on Jul 25, 2012
SOURCE: Samsung DMT300RFS dishwasher; low-level water error
A Samsung service tech showed me how to fix this one. You can take that float and the white box apart from the dishwasher and once opened, if its like mine, there will be gunk on the float and in the box at the line where it fills with water. This gunk floats in there and prevents the float from swinging and activating the switch. Just clean that gunk out with a toothbrush, I end up doing mine about once every four months, and it should work fine again. This tech said to prevent this, make sure the water is hot at the beginning of the cycle and pre-rinse the dishes-but this doesn't seem to work with mine.
Top Samsung Dishwashers Experts
vince
Paul Carew
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
