Your back up data is currupt, you need to change your p-sens-p value check your door spect for all default value. after that clean your sensors that is found below the black developing assy. take machine off unplug from outlet replug turn machine on DO A GRADUATION ADJUST that should solve the problem / if not unplug the the same sensors , then repeat the first prod.
after that clean your sensors that is found below the black developing assy...
can you tell me wich sensor pls...do you mean black sensor...if yes i changed it all...the black sensor assembly...
another problem with CLC 4000...
The error is E062-0010....drum thermistor problem...
can you help me wich drum?
thanks,.
