I keep getting error code 041, I cannot record any more shows (even thought there are 45 available hours) and to delete some recordings. I have deleted recordings, and continue to get this message.....
Wlmbug,
Our receivers can only hold a certain number of timers before some have to be deleted. To fix this message, on most receivers, press the DVR button three times to access "Daily Schedule". From there select 'Timers' then 'Edit Timers'. Once they have been deleted, more can be setup!
If you have any questions, or need further assistance, let me know!
Tommy Faust
DISH Social Media Representative
Hello, I understand the process for deleting timers. That was not my problem. My problem was.......I was NOT out of recording time by at least 20 hours, and I was still getting this error code when I tried to "record remainder of event" while watching live tv. Since I sent this question in, it has, for whatever reason, cleared itself. thank you.
SOURCE: Reciever Not Recording
Turn off the receiver, unplug the receiver, wait 30 seconds, plug it back in, and go through the setup again. This hard restart clears the memory and restarts the DVR software(clears any software glitches) This should fix this problem assuming that your satellite signal is good. Check that during the resetup. Most transponders will show between 70 to 100 signal strength. (Minimum is 70 for error free reception) Several transponders will show 0 as they are dead on the satellite, and not a receiver problem) If your satellite signal is in the 70's or less, you either live in Maine or you may need to realign the dish or something is blocking the signal like a tree or bush growing that is partially blocking the signal causing the signal to drop out(partial recordings)
SOURCE: will not record and also keep geting error nodisk
Did you try a disc cleaner? Maybe the lens is just dirty.
SOURCE: Thomson DT16300 TV Recorder Continually Freezes
Just got off the phone to TopUp TV and they knew how to sort this out.
Follow these steps
1. Turn on unit and press menu
2. choose set-up
3. then choose Help
4. On the help screen type the number 1397 on your remote - This will take you to an Engineer set-up screen.
5. Scroll down to option 7 (disable library video window) and toggle this option to "YES"
navigate back to your programs and delete the recording that was giving you the problem.
SOURCE: DVR-625 deleted almost all timers, stopped recording shows
Unfortunately the hard drive is failing and you will need a new one.
Thanks for using Fix Ya.
SOURCE: DRT400 TiVo 40-Hours Video Recorder: unable to delete programmes...
Do a complete CLEAR and ERASE.
This should fix the problem.
