Icom Ic 2200h Vhf Mobile Two Way Radio Ic2200h Ic2200 H () Logo
Franklin Sanor Posted on Oct 23, 2012
Programming Radio Using the same computer as I use for my UV-5R, I fail to connect to the ICOM. I have both CHIRP and the Icom software. Niether will connect. Is there a certain sequence or a different driver needed for the Icom cable?
  • Franklin Sanor Oct 25, 2012
    I have ICOM program copyright 2003 so that seems to be legitament. The Chirp is the latest daily build. Chirp gives a response "error global name "data undefined". Both seem not to connect. The cable is a real prolific cable. The driver is that indicated as the one needed.
    The computer used is Vista based.
5 Related Answers
Gavin93
EDACS
  • 66 Answers
  • Posted on Sep 07, 2008
SOURCE: Icom F21
It's a frequency error. It can be corrected, just give me some time, I need to figure something out first. It might take me a day or two.
Anonymous
  • Posted on Nov 16, 2008
SOURCE: Handheld Marine Radio
This applies to all battery powered radios. Take out the battery and measure the voltage to see if it is indeed charged. If it's not, then the fault is the charger or the battery or both. If the battery voltage shows that it is fully charged, then clean the terminals on the battery and on the radio with a pencil eraser to remove any corrosion. If still no joy, then look up in your user's manual on how to do a reset. If you don't have a manual, get on the ICOM website and download one.
Good luck.
Anonymous
  • 17 Answers
  • Posted on Feb 02, 2009
SOURCE: Programming an Icom IC R5 scanner
This is a problem with any scanner which has no keypad..
First set the squelch (gets rid of the hissing noise and allows the radio to scan)
to do this....
On the side are 2 buttons, the bottom one is monitor.
press and hold then look at the display,
turn the top dial until "AUTO" appears,
The squelch should now keep the radio quiet.
Now the tuning step..
You need to set this because if your radio was on 450.000 and you wanted to listen to 450.012.5 you would miss it if your radio was making 000.025 "steps". IE you would need 12.5 steps. This is the most common step used by ambulance etc in the UK, you will need to check local band plans.
Stick with 12.5 and you should get most stuff on VHF / UHF.
For airband 12.5 will get most stuff, but some is now changing to 8.33.
For HF (below) 136 Mhz I'd use 5
To set the step....
On the front there are 4 big buttons.
press [V/M.S.MW.SKIP] to select VFO mode,
then press [BAND.LOCK] to select the band you want to listen to,
then press [TS.SET] to enter the step
turn the dial to select your step (stick with 12.5 for now)
press [TS.SET] to exit back to VFO mode
To scan...
First set the scan type...
Press and hold the one that says [MODE.SCAN] for 2 seconds and look at the display,
turn the top dial until the screen reads ALL,
press [MODE.SCAN] again and the radio should start to scan with the 12.5 steps you set earlier.
If you want to change scan direction, just turn the top dial.
If you want to stop the scan, just press [MODE.SCAN].
When you hear something interesting, make a note of the frequency on the display.
To set memories (store frequencies).....
to get close to the frequency you made a note of, press [BAND.LOCK]
Then set the actual frequency with the top dial,
press and hold [V/M.S.MW.SKIP] for 2 seconds to select memory write mode (1 short and 1 long beep)
turn the top dial to select which channel you would like to overwrite. Start with 01.
press [V/M.S.MW.SKIP] for 2 seconds. ( 3 beeps )
Thats it!
Any more problems just post on here and either me or someone else will help.
M3ODQ
Anonymous
  • 8 Answers
  • Posted on May 02, 2009
SOURCE: If you where going to Buy one radio which one would you Buy?
I am a marine electronics technician with 28 years experience. I have also been a licensed amateur radio operator for the past 12 years. Based on my professional experience with both brands (Icom and Yaesu), I have to advise you to go with one of the Icom units. The Yaesu is a good radio, but Icom's customer support is far superior. I have had no problems dealing with their service department over the years, something I can't say about Yaesu.
Hope this helps.
Anonymous
  • 12 Answers
  • Posted on Sep 13, 2009
SOURCE: how to program the emergency rd button on IC-F43TR
First do you have the correct software? Second do you have the correct programming cable? If the first two are OK you are half way there. Open the program and download the radios info to the program, it's that little computer icon. Click on "common settings", you will then see "key & display" click on that. You should have a small window with all the buttons including the red one. I hope this helps.
Top Icom Boating Experts
ADMIN Andrew
ADMIN Andrew
Kevin Gens
Level 1 Expert
Anonymous
Are you an Icom Boating Expert? Answer questions, earn points and help others
