Computers & Internet Logo
A
Anonymous Posted on Nov 11, 2012
MS8308e wire diagram
Need a wiring diagram of motherboard
5 Related Answers
Anonymous
  • 86 Answers
  • Posted on Jan 28, 2008
SOURCE: INSALLING A MOTHERBOARD
From what little information I could find, your motherboard does NOT provide a CD_IN connector. ONLY the GA-PCV2-DVI version provides the connector you're looking for, while the GA-PCV2-DSI version of the m'board (the one you own) does NOT have the CD_IN connector... wish I had better news than that for you...
Just FYI, you can download a LARGE file (~55MB), which contains ALL of the drivers AND the m'board manual in .ZIP format directly from here:
http://www.idot.com.tw/en/downloads/MB-PC1000G1500G(GA-PCV2)/V1.0CD.zip
It took about 17 minutes to download that entire file to my HDD, over a broadband connection, so I can only guess that the server is restricting download speeds...
Once you download that file, you can unzip it and locate the manual (in .PDF format), which is the "PCV2_Series.pdf" file...
In the manual, you will find the information I've provided here on page 12, so you can verify what I've told you...
Good luck; I suspect you'll have to install a compatible soundcard with a CD-IN connector if you really want one...
Kristoffer Martin
  • 293 Answers
  • Posted on Sep 12, 2008
SOURCE: wiring
The user guide for the motherboard should have a full diagram for all the wiring you have. Here is the link: http://www.manualnguide.com/dl/8959/
Anonymous
  • Posted on Nov 15, 2008
SOURCE: Wiring diagram and manual needed
Hi my name is Tomas and i wounder if you can help me with this problem ..i need a wiring diagram to Ms-7061 ver 1.0 can you send it to my email gsson.t@telia.com best regard Tomas
Anonymous
  • Posted on Jan 01, 2009
SOURCE: diagram of motherboard "kvm266pm-u"
hi to all if u are needing a manual for a KVM266PM-U motherboard this is a good link http://www.mercury-pc.com/download/uploaded/drivers/DVD/Webdriver/MB/OLD%20MB/AMD%20SocketA%20Socket%20462/KVM266PM-U-400M-U%20(v3.0B)/KVM266PM-U-400M-U%20(v3.0B).pdf
Anonymous
  • Posted on Mar 30, 2009
SOURCE: abit an7 motherboard front panel wiring diagram needed :)
Front pannel audio is located left of the pci slots
: : : . : : :   thats what it looks like         from left to right there are seven sets of pins 1234567.
3 and 7 should be the pins you want for a standard front panel audio as far as i see in the manual ICEBOX
1helpful
I need a wiring diagram for the syntax sv266ad motherboard
You wont find one.
The only way you could get one is if the manufacturer of the board would release it to you, and they never do...its proprietary information.
What do you need to know about the board that your looking for a wiring diagram. And just to mention there is no wiring diagram persay.....its a routing diagram, as there are no wires.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Wiring for a tekram s381m
You need trhe manual. I don't think they have wiring diagrams for these boards. Try http://www.tekram.com.cn:8060/UserManual.ASP?Product=S381-M%20series
8helpful
No sound matsonic mspm800 motherboard problem
http://www.matsonic.com/drivers/view.php?modelID=MS8308E
The above site address is the only one I could come up with nearest your motherboard number copy and paste the first line into address bar go there it lists most of the drivers for motherboard including sound hope this helps
Motherboard
We need a wiring diagram front panel to my motherboard
2answers
Need wiring diagram for emachines t2200 motherboard
If you are replacing the power supply and it has 4 pin 12v conector and your motherboard doesn't, just disregard the 4 pin plug. The 20 pin conector will supply sufficient power for the processor. Many of the older motherboards did not have a separate 12v supply for the processor.
4helpful
3answers
Motherboard wiring diagram
i need a wiring diagram of my mother board...usb power etc etc. any idea where i wud find this
regards Des
2helpful
MOTHERBOARD AUDIO PIN CONNECTIONS
The pins are pretty much universal, I'm 90% certan that the other one of these is correct for you.
Top Matsonic Computers & Internet Experts
Anonymous
 Wampir Computers
Wampir Computers
Level 1 Expert
Are you a Matsonic Computer and Internet Expert? Answer questions, earn points and help others
