Brother MFC 240C All-In-One InkJet Printer Logo
Posted on Jan 14, 2009
Printer is on Pause
Under printer Status it is on pause. How do you get it off pause so I can print my documents?
  • wjmart Jan 22, 2009
    printer has been paused and wont print it is a epsondx4400
5 Related Answers
Anonymous
  • 4 Answers
  • Posted on Oct 06, 2008
SOURCE: brother printer MFC 210C
I was getting a constant "Paper Jam" message, even though I thought I had cleared the jam. If you are having this problem, go to this site:
http://welcome.solutions.brother.com/BSC/public/eu/gb/en/faq/faq/000000/000400/000095/faq000495_002.html?reg=eu&c=gb&lang=en&prod=mfc210c_all&Cat=4
I didn't realize there was a removable cover on the back of the printer. I took it off, and sure enough there was a small triangle of paper approximately 1/2" on a side jammed in one corner. Earlier, when I removed the larger piece of paper, I had not noticed the missing corner. Fixed the problem!
Anonymous
  • 8637 Answers
  • Posted on Jan 27, 2009
SOURCE: Brother HL 5250 DN status shows "error". Won't print.
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
A
Anonymous
  • Posted on May 17, 2009
SOURCE: my printer is on pause printing , how to get it off this option
if you can't get it off "pause", then re-install software.
nalin_elliot
Nalin DSouza
  • 224 Answers
  • Posted on Jun 19, 2009
SOURCE: HP 2840 printer pause will not resume
uninstall your printer and then re-install it that should fix your issue,it could be a bad version of an updated driver that is causing the problem
Anonymous
  • 23 Answers
  • Posted on Sep 25, 2009
SOURCE: I had my printer (hp psc 1200 series) try and
You need to go ahead and simply refresh a service known as "Print Spooler"
here's how you do it..
for Windows XP:
>> click on start
>> click on run
>> type in " services.msc " and hit enter
You will see a list of service names alphabetically arranged on the right hand side..
From there look for the service name "print spooler"
>> right click on it
>> click on stop
wait for 10 secs
>> right click on it again
>> click on start..
>> restart the computer..
>> you will find your document deleted :)
plz rate if you find it helpful. thank you
Norman Weimar
Norman Weimar
Sudeep Chatterjee
Sudeep Chatterjee
