Dishwashers Logo
ofer Posted on Dec 18, 2012
Error code h03 - Bosch Dishwashers
5 Related Answers
Anonymous
  • 6966 Answers
  • Posted on Jan 05, 2008
SOURCE: H03 Error
With the indulgence of bbtoast and DARKLORD1...
This is a known common problem with most Panasonic DVD units. An HO3 error display indicates a "Traverse Servo Problem". The traverse servo is the motor that drives/moves the optical pickup (lens + cradle) to slide along a shaft while reading the disc.
A HO3 error could either indicate problem in the:
1. shafting/slider: possibly clogged with dust, dirt or dried up lubrication;
2. stuck up/defective traverse motor;
3. defective wiring connection, electronic regulator/controller.
As you will note, all of the above requires opening the unit and component level repair. Since this would need familiarity with electronic components/circuitry, use of a DVM and possible a soldering iron, perhaps you might be better off seeking the services of a qualified professional.
Hope that this be of additional help. Pls post back how things turned up or should you need additional; information.
Good luck and kind regards.
Ironbar66
  • Posted on Feb 02, 2008
SOURCE: panasonic dvd-ls91 erro code H03
I experienced the same dreaded H03 error code recently. The fix was simple:
Open the DVD lid. In the center is the black plastic spindle. To the right of the spindle is the laser reader which slides from side to side.
When my player was in error mode, the laser reader was stuck in the far right position on the track. To fix the problem, gently, but firmly push the laser reader to the right until it clicks in to proper position. For mine, I pushed it to the right about an eighth of an inch before it clicked.
Insert a disc, and turn the player on. This should fix the problem, at least it did with mine.
Anonymous
  • 4102 Answers
  • Posted on Mar 19, 2008
SOURCE: code h03
Hi the code HO3 relates to their being a problem with the laser you could try using a lense cleaner and see if its just dust or something like that failing that its going to be getting the laser replaced let me know if you need further assistance.
If you type in your search box this
DVD-LS90 Portable DVD Player with screen HO3
then search this will then list a load of sites that cover your dvd player and will also tell you what that error code means have a look and if you was getting it repaired then their should be a few sites that are selling the parts you need ok
bytecrawler
  • Posted on Jun 13, 2008
SOURCE: panasonic DVD ls 850 , H03 Code error
I have an LS82 and the following advice from www.avsforum.com fixed the problem for me. Note that the number of screws that hold the bottom on the machine vary depending on the model. Also the server frame might be plastic instead of metal:
Originally Posted by Hossam fixing code H03is very simple but needs some courrage and small philips screw driver.
the problem arrise from the laser lamb which moves up and down the disk through a mechanical shaft
I do believe when we press the back space for long time it will take the laser lamb beyond its limit and get stuck at the end of the rotating shaft so the servo motor gets difficulty and resistance to get it back to tract
all you have to do is open the back of the LS50 " 12 small screws"
mad.gif when you remove the back cover be carful not to damage the cables mad.gif .
you will find the servo motor and laser lamb on one metal structure hanged to the body by three rubber suspensions
remove the whole structre and turn it upside down slowly
move the small black rotating joints up or down you will notice the the mechanical shaft will start rotating and the laser lamb will start to move away from the servo motor relasing it from where it get stuck
and it will work perfect after that
return the back cover and screw the 12 screws and you are done
Anonymous
  • Posted on Jul 09, 2008
SOURCE: code H03
error code h03
What does error H03 means af the Philips portable dvd PD9030?
Go to this link http://tech.rickumali.com/blog/2008/12/30/fixing-my-portable-dvds-h03-error
Treadclimber TC20 giving error code H03 H13 H24 on starting
Dear Sir:
You must explain them, such as you did with the error, The PROM, EPROM, was corrupt, there are NOT anything we can do for fit it.
However if you wan to RUN the software calibration for diagnose, troubleshooting, do it.
sincerely. God bless you
2helpful
My bowflex treadclimber tc 20 is putting out error codes H03,H13,H24 whats wrong
I have the exact problem. My machine is 3 days old. I am also getting this H03, H13, H24 error. I called the 1-800 number for the Treadclimber TC20 and they informed me that a handful of machines were sent out with a bad control board. I am waiting for a replacement board.
5helpful
5answers
Call for service: h4-00
H4-00 means thst the copier isn't warming up quickly enough. Try this code to reset it. Press the following buttons in this order: #, interupt, C, interupt, 1, 4 . machine will say sim 14 trouble clear are you sure. Press the OK button. This should reboot the copier. Most likely the machine is in need of a heater lamp in the fuser unit.
7helpful
Portable dvd player h03 what to do fix it?
this error code means that there is something wrong with the laser lens most portable dvd players over time get weak motors or lenses you may try to take a small cloth or cotton ball and move the lens back and forth from the spindle to the end then place it as close to the spindle as you can then turn it on and you might be good to go! if not then you have a bad motor and may have to replace it! hope this helps!
1helpful
2answers
Panasonic DVD ls 850 H03 Code error, how to solve this problem
H03 is a mech problem if I remember you need to take the bottom cover off and remove the mechanical assy (laser chassis) then you need to clean the worm gear (this is the gear that moves the laser back and forth) even the littlest amount of dirt will jame this gear and make the unit go into H03 Mode
Pls help
H03 error means Traverse servo error. The spindle motor may be defective.
Code h03
2helpful
1helpful
3answers
Error H03
I have had this problem for 2 years, mech.is hanging up. mine was replaced.... 3 weeks later same problem. I take out the disc and very GENTLY press one direction or the other to free it up. works great for a whole movie or several movies in a row. A small amount of electronic lube helps, just make sure you don't get it near the laser head or it will mess things up. Just clean it off real well if you get some on it.
Top Bosch Dishwashers Experts
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
