NEC ETW 16DC-1 Corded Phone Logo
Kimberly Callahan Posted on Jan 15, 2009
Function I am trying to find out how to take off DND on these phones
Anonymous
Level 1:
Problem Solver:
  • Contributor 16 Answers
  • Posted on Jan 17, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
16
Questions
0
Helped
10226
Points
30
If your main system cabinet (in some closet somewhere) is plastic, you have the NEC Electra Professional Level I system and the DND cancel procedure is <FNC>, 60, <FNC> when the phone is idle. If your main system cabinet is metal, you have the NEC Electra Professional Level II system and the DND cancel procedure is <FNC>, 69, <FNC> when the phone is idle. You can also press "42" while hearing intercom dial tone. The most common cause of accidentally setting DND is by dialing "40" while hearing intercom dial tone (Level II system).There is a slim chance your main system is not the Electra Professional series. If either of the above do not work, let me know.
My feature key is lite and I have DND. How do I get this to cancel
Remove the Line wire from the back of the phone and then plug it in again. See if the DND function is still on. If yes : pick up the handset or press Speaker key and then press the corresponding DND Softkey (the buttons right under the LCD). If you don't see any DND text on the LCD of the phone try to move to another pair of Softkeys by pressing the last button (see the >> on the LCD)
1helpful
I have an issue with my FWD/DND function. Until yesterday, I was able to receive "in" calls. Apparently I accidentally hit the FWD/DND button! At first I wasn't getting ANY calls (never used...
I don't know about a "user guide" but the Operating Manual would work wonders. http://www.public.carl.airpost.net/Pana/TDA/200_TDA_OM_06-121.pdf
The FWD/DND button has 3 steps of keypress, Off, FWD, DND. The idea is you press it until it stops flashing or being lit and you have nothing set. If that doesn't work, try Call FWD/DND cancel, *7100 on the intercom.
Carl
2helpful
I have a Nortel Telecom Meridian phone at work. I often get unsolicited calls on my work phone and I just want to ignore them instead of answering them. How do I mute the ringer on my Meridian phone. It...
You can use the do not disturb function on your set. When used it will stop all ringing on your set(both line ring and intercom ring). To turn on DND, press feature 85, to turn the DND back off press feature #85.
2helpful
2answers
Get rid of the display "DND EXTERNAL" and enable the function of the cordless DECT. Our terminal is UX5000.
www.necux5000.com/
Please find above your support website. Below please find your user manual. If you look in the manual it shows you how to do what you want.. When in doubt RTFM.
www.devicemanuals.com/.../Sharp-Fax-UX-5000-Operation-Manual-TWpVMk9Uaz.html -
software features manual below.
www.necux5000.com/dealer_area/documents/software/0913201_rev3.pdf
DECT manual below...
www.home-electronics.net/ge/pc/IB/28112EE3_IB.pdf
Aug 12, 2010 • Cell Phones
4helpful
How do I divert calls to a mobile number and then undivert calls
pickup the handset (phone... watever) and press the FWD/DND button then press #2 then type in the number of the mobile (or number you want to forward to...), and hang up the phone... then when your finished with the call forwarding function, press FWD/DND again and this time press #0
What 2 does it turn on the call forwarding feature
. and 0 turns off forwarding/do not disturb functions
theres 5 different functions after you press FWD/DND
0: turns FWD/DND off
1: put the phone into Do Not Disturb Mode
2: call forwarding
3: Busy-Forwarding.. which means if your on the phone and someone rings, it forwards them to the number you specify
4: No Answer- when you don't answer the phone if forwards the caller onto the number you type in
and lastly 5: Busy/No Answer- does both function 3 & 4
i hope i've helped
, Cameron
3helpful
3answers
Zero Rings during meetings
With either a Do Not Disturb (DND) or Call Forward all calls command. On a TA-824, DND is set up with the command 714# on the intercom. It will light the DND button. It's cleared with 710#. There is no function to the button, ie you can't push it on and off. If you have voice mail, you can set it to forward all calls via the 711 (vm ext) #. It will blink the FWD/DND button.
As an aside, 7341# stops paging to the phone. 7340# brings it back. Again, these are TA-824 commands.
Carl
Programing DND Button
You can not use DND on an analog phone. Are you sure this isnt a Partner 6? If so, you can.
Top NEC Lands Phones Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Don A
Don A
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
