Frigidaire Affinity ATF7000E Front Load Washer Logo
Anonymous Posted on Dec 25, 2012
Error Code E63
Washer stops mid cycle. No other errors.
  • Official Brand Answer 4,342 Answers
  • Posted on Dec 27, 2012
Electrolux
Level 0:
Answers
4342
Questions
0
Helped
1495608
Points
5908
From my research, it looks like the error code E63 related to the heater and ground connections of the unit.
Testimonial: "It was a loose connection in the wiring harness. Thanks very much!"
  • Electrolux
    Electrolux Dec 27, 2012
    Check heater coils and connections for short circuits to the cabinet. Replace heater and/or wiring and retest.
  • Anonymous Dec 29, 2012
    I checked all the wiring, and found a loose connection. It works fine now.
5 Related Answers
Anonymous
  • 1294 Answers
  • Posted on Jan 24, 2008
SOURCE: Washer stops and signals E20 error code
Click on your model number (below FIXYA) on this website, & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
And dont forget to rate me on this great site!
sagacious
GORDON'S APPLIANCE SERVICE
  • 283 Answers
  • Posted on Feb 08, 2008
SOURCE: Affinity E21 error
E21 means "Not pumping out fast enough". Could be debris caught in the pump inlet sump or pump body.
a75737b.jpg Disconnect the inlet sump from the pump. Disconnect the outlet hose from the pump. Remove the (2) screws, one on each side, holding the pump housing to the washer base. Unplug the wires from the pump motor and lift the pump assembly out.
Anonymous
  • Posted on Jun 19, 2008
SOURCE: Frigidaire Affinity ATF6000ES frozen
IF there is an E attached to the 45, it is your control board and the control board would need to be replaced. This is per the "Washer Tech Data Sheet"Hope that helps...
Anonymous
  • 79 Answers
  • Posted on Oct 20, 2009
SOURCE: e20 error code. what is that?
Read here :
http://www.fixya.com/support/t615626-error_code_e20
Hope this helps. =)
Anonymous
  • Posted on Dec 03, 2009
SOURCE: I have a Frigidaire Gallery front load washer with E10 error code
When ours does that it is because of the hard water build up. We have to un-hook the hot water clean out the minerals and it stops doing it.
Top Frigidaire Washing Machines Experts
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
