Sharp AR-M550N Copier Logo
A
Anonymous Posted on Feb 14, 2013
Error Code h3-02 error code for sharp arm550n
5 Related Answers
checkitright
CheckitRight
  • 1363 Answers
  • Posted on Oct 20, 2008
SOURCE: H3 ERROR CODE SHARP AL 1631
H3:
00:TEMPERATURE OF FUSER UNIT HIGH,THERMISTOR CONTROL BOARD FAILING
Did you replace the thermistor? check the thermofuse also for continuity
san3409jl
  • 190 Answers
  • Posted on Jan 27, 2009
SOURCE: error code Sharp AR-M 257
The F2-04 error code you are getting is that you are using the wrong toner.It may be form sharp,but it toner chips is different.Only the chips swapping at the toner back can help you.
Anonymous
  • 95 Answers
  • Posted on Apr 12, 2009
SOURCE: Sharp Copier AR -407 Error code H3-00
H3-00 means there was a problem in the fuser unit of the copier - a temperature problem. The correct temperature is not reached within a certain time.
It could be a thermostat or thermistor problem - both monitor temperature. you could remove the fuser unit and make sure these items are clean - no build up on them. there should be a center and side thermistor.
You can reset the error code in SIM mode by pressing the following keys one after the other "P" "interupt" "C" "interupt" then 14 and start/copy key. confirm if required. make sure the copier is restarted afterwards.
If the error persists then you may need new thermistors.
Hope this helps.
Anonymous
  • Posted on Jun 06, 2009
SOURCE: sharp ar-m205 error code E7 11
U HAVE TO UPGRADE THE FIRM WARE BY ENTERING SIMULATION 49-1 THE VALUE IS d THEN UPDATE THE FIRM WARE IF U HAVE IT
electronacs
electronacs
  • 19 Answers
  • Posted on Jun 19, 2009
SOURCE: sharp 5320 H2 error code
this is a fuser error message. You must fix the problem causing the fuser to post an error. Then clear the message.
Sharp AR-M316 photocopier. f2-02 error on it. How can I clear f2-02 error on this Sharp photocopier please?
Sharp ARM316 - Error Code: F2-02
PrintCopy .info https://printcopy.info > model=ARM316 > code=F2-02
Code: F2-02; Description: Toner supply failure. The value judged from the actual toner supply hysteresis differs greatly from the toner sensor value.
Missing: photocopier. ‎' Must include: photocopier.
Sharp MX-3640N A3 Color Laser Multifunction Printer. Error service code: C1-14.
Question edited for full 'make model (what it is)'.
Error Codes > Sharp > MX3610N > Code C1-14 - PrintCopy .info
https://printcopy.info > code=C1-14
Code: C1-14 · Description: Main charger trouble (Color) · Causes: The main charger unit (CMY) is not installed properly. There is an abnormality in the main ...
SOLVED: Error code C1-14 - Sharp MX5001N - Fixya
https://www.fixya.com > ... > Sharp
Apr 9, 2019 - Code. C1-14 · Description. Main charger trouble (Color) · Causes. The main charger unit (CMY) is not installed properly. There is an abnormality ...
How to remove error code C1-14 For Sharp MX-2501N - Fixya
Sept 5, 2019
Questions & Answers for: sharp error code c1 14 - Fixya
Nov 16, 2019
SOLVED: Sharp mx 3100n C1-14 error code - Fixya
Dec 12, 2020
Error code C1-14 - Sharp Mx-2310u Color Copy/print/scan
Apr 8, 2013
More results from www.fixya.com Missing: 3640 ‎' Must include: 3640
Sharp MX-2630 Error C1-14 - Copytechnet
https://www.copytechnet.com > ... > Sharp
Apr 27, 2019 - Error Code Sharp MX-2630 Error C1-14. If this is your first visit, be sure to check out the FAQ by clicking the link above. You may have to ...
Sharp MX2640 error C1-14
Jun 20, 2017
Error Code C1-14 on MX3100N
Jul 23, 2011
MX-6240, 7040 (Polaris) with error code C1-0X ...
Jul 17, 2015
More results from www.copytechnet.com Missing: 3640 ‎' Must include: 3640
Codes erreur SHARP - Sharp Photocopieur
https://www.photocopieur-sharp.com > codes-erreur-sh...
C1. C1 10 MAIN CHARGER TROUBLE (BK). C1 14 MAIN CHARGER TROUBLE (COLOR). C4. C4 00 PTC TROUBLE. E7. E7 01 MFP IMAGE DATA ERROR. E7 03 HDD TROUBLE.
Sharp MX-2310U, MX-3111U (SERV.MAN68) Technical Bulletin
https://servlib.com > Sharp > Printer
MX-2310U, MX-3111U (serv.man68). CCE-1425 MODIFICATION OF TROUBLE CODE C1-10 or C1-14 DUE TO DEFECTIVE MC PWB - Sharp Copying Equipment Technical Bulletin ...
Error code F2
ve change the toner cat to the original catr still showing, also ve change various type of chips still showing
ERROR CODE F2-00
Please you should replace your toner cartridge.If you have new toner cartridge than the chip destination error.Thanks best luck
Error f5 05 en copiadora sharp
I know to fix this problem.But I need money.If you are agree to pay 5usd by my PayPal account .please send to xptareq2000@yahoo.com
2answers
Sharp ARM550N error F3-12
You will need to reset the error code. Try crop 15 or 14.
10helpful
2answers
How to remove h5-01 error code on a sharp arm550n copier
This is either:
10 continuous POD1, POD2 or PPD2 JAM
OR
Other models this indicates too many fuser jams. The fuser error reset code will reset the machine so it will run after the problem is fixed.First remove any jam in the fuser then enter tech mode;
press program, * ,clear, * enter 1 4 press start then turn machine off and then back on.
Top Sharp Office Equipment & Supplies Experts
George Mclaughlin
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
