RTO Takagi T-M1 Mobius Gas Tankless Water Heater Logo
John Adams Posted on Mar 02, 2013
Error code 541 - RTO Takagi T-M1 Mobius Gas Tankless Water Heater
  • John Adams Mar 08, 2013
    541 is the 2 way valve error, could be the computer, or the valve itself. The valve has a motor that could be bad. As a temp solution you can unscrew the motor from the valve and turn the valve manually but leave the motor connected, That should fix the problem, the water temp could flactuate a bit since the valve is not being controlled by the computer.
    You can also try to descale the unit, that will most likely make the valve move freely and if the motor and the computer are working then you are done, problem fixed.
Barry Zimmerman
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Sep 30, 2013
Barry Zimmerman
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1164
Points
Error Code 541 indicates that the Two Way Valve is malfunctioning. This assembly consists of a small motor and a rotating ball valve that is operated by the motor. The replacement part is only sold as a unit (Motor and valve) for about $200. It is located in the lower left of the unit, behind the flow valve. (i.e. it is hard to reach in order to service it). You basically have to take out the exhaust fan, take out the flow valve in order to replace the 2-way valve. It's doable as a DIY, but it's not trivial.
The valve could be crusty from deposits, so before taking everything apart, it would be wise to flush the heater for 45 minutes with anti-scaling and a recirculating pump to see if anything breaks loose. (using the service valves that should be mounted on the bottom of the unit)
  • 4 more comments
  • Les Bowles
    Les Bowles Jul 14, 2014
    The descaling procedure freed up the valve and got it operating properly. Try this FIRST. I tried to take out the fan and it is not possible to do with the T-M1 installed. The bottom of the fan housing is in a recess at the bottom of the heater case. Removing the fan is a MAJOR disassembly process. Removing the flow valve and two-way valve requires several new gaskets for re-installation as well. Refer to the IPB for the T-M1. It's not a DYI project unless you have plenty of other parts on hand and ready to go.
  • Les Bowles
    And I should add that you have plenty of time (hours) that you can do without hot water to field strip your heater to replace the two-way valve. I could not see where the valve can be "adjusted" in place to manually open it. To remove the valve, the entire hot water output line system has to be disassembled plus removal of electrical components.
  • Les Bowles
    I did a 1.5 hr vinegar flush. Bought a 1/6 hp submersible pump and a 5 gal orange bucket from the orange big box store. I had an extra set of washing machine hoses on hand. Used 2 1/2 gal of white vinegar as per the descaling procedures.
  • Les Bowles
    http://www.takagi.com/download/product_m...
  • Barry Zimmerman Jan 02, 2015
    I am glad to hear that you got the unit working again with just a flush. I was not as fortunate. I was able to disassemble everything with the TM-1 installed. Getting the fan out is a little tricky, but not impossible - after all, the factory has to be able to get the fan in/out! Yes, some new gaskets are necessary. By the time I ordered parts and did the work, our hot water was out for five days.
    I should add that an Error 541 (stuck 2-way valve) might have fried the main computer board with an over-current draw from the stuck 2-way valve motor. Takagi admitted that the Error 541 often requires a replacement of the motherboard. So it's an expensive problem if this occurs (for me, I had to replace the motherboard). My advice? Be diligent about flushing your heater with de-scaling solution at least once per year, more if you live where the water is hard with minerals.
Noritz: Tankless Water Heater. I have an error code 99 on my Noritz tankless. How do l reset it please?
Remove the bird's nest in the flue.
The 10, 59, 90 and 99 error codes indicate that a Noritz heater has experienced a combustion abnormality. In most cases, it is the result of an obstruction in the heater's flue. Examine the flue to see if it is blocked by debris and clean if necessary.
How To Resolve The Seven Most Common Noritz Tankless ...
Noritz https://www.noritz.com > Blog
Nov 16, 2015 - This error code involves a breakdown in communication between two tankless water heaters using the Quick Connect Cord. It can occur when more ...
Troubleshooting Noritz Tankless Water Heaters and Error Codes
home-water-heater.com https://www.home-water-heater.com > noritz-error-co...
Error code 90 and 99 ... Action: Check for the obstructed venting, improper gas burning (flame shape and color change). Ensure the water heater gets the ...
Error Codes for a Noritz Water Heater - Waterheatertimer.org
2answers
2answers
How do you turn the valve manually?
the valve has a shaft with a small pin, it can be turned with a needle nose plier.
Abnormal two-way valve
The PC board says it needs to be swaped out
What does error code 13 mean?
1) Copy following links for Rheem tankless error codes
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
http://waterheatertimer.org/pdf/Tankless-Error-code-13.pdf
2) Maintain water heater as shown in product manual to avoid common error codes.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
What does code 36 mean
Error code 36 does not show in Rheem tankless manuals.
Copy following link for general troubleshoot and error codes, and Rheem contact information:
Error code 36 does not show in any resource, including 2008 service manual, or 2012 product manual.
Check that remote control display is illustrating the correct number.
For example there is error code 35.
1helpful
2answers
Takagi code 541
Code 541 means the 2 way valve is not turning, that could be the valve has build up calcium due to hard water and the attached motor is not able to turn it, or the motor is broke or finally the controller (Compute Board is defective).
The 2 wau valve sits behind another valve when looking at the unit on the left hand corner, it must be taken out first to gain access to the 2 way valve.
The 2 way valve motor can be seperated from the valve by two screws and the valve can be manually opened but turning it to the horizantal position, there is a pin on that shaft.
Turn kon the heater then but leave the motor connected, if the motor turns for short time then the PCB is most likely ok. This usually indicated that there is too much of build up inside the valve. If the tankless was properly with bypass valves (outside of the unit) installed then this can be easily fixed.
Turn the unit off and run with an external pump and bucket with vinegar for about 30 minutes by using the bypass valves. This will clean the 2 way valve from inside and should turn then easily and the motor will be able to control it. This is usually beyond the DIY scope, call a real pro for that.
http://www.justtankless.com
1helpful
No hot water error codes 76, C4,C7
Before calling service tech, open following links for Rheem troubleshoot resources including rheem chat, error codes, possible maintenance and service manual.
Error codes are considered start-point for troubleshooting.
Multiple error codes can mean PC board failure.
http://waterheatertimer.org/pdf/Rheem-error-code-C7-76.pdf
http://waterheatertimer.org/pdf/Error-code-13.pdf
http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
1helpful
Code c4-13
Before calling service technician, open following link for Rheem troubleshoot resources including error codes, Rheem chat, and possible manual:
Error code C4 13 is bad oxygen sensor, inadequate incoming air supply, or bad venting. Also bad PC board, or internal wiring, or temperature set too high, damaged burner parts.
http://waterheatertimer.org/pdf/Bosch_Ventilating_tight_houses.pdf
Tankless require yearly maintenance to combustion chamber and burner parts.
Prescribed maintenance can correct some of the issues in error code 13.
Top RTO Water Heaters Experts
jdthefixer
Paul Carew
Are you a RTO Water Heater Expert? Answer questions, earn points and help others
