SOURCE: wine refrigerator is not worjung
IN YOUR USER MANUAL THERE WILL BE A TROUBLE SHOOTING SECTION. CHECK IT OUT AND IF POSSIBLE GET A TECHNICIAN.
SOURCE: Error code in the top zone E3
An E-3 error code on your product indicates a problem with the DC fan in the upper zone. Your issue could be with the fan motor, control board or connecting wire harness. A DC motor can not be ohmed out like an AC motor, so if you detrmine the motor is not running, check for DC voltafe at the motor connections. If there is 12 to 24VDC, then you have a bad motor. If no voltage is present, check the output on the board. Before replacing an expensive circuit board, you may want to have a professional service tech come out and diagnose your problem. ***ALWAYS remove electrical power from the product when removing panels to gain access to components, and also when putting the panels back in place.
SOURCE: E3 error code on my Magic Chef Wine Cooler - what
could be a broken fan, compressor gone, thermostat. neither one you can fix. you need a refrigeration mechanic or a new fridge
SOURCE: ovens not lighting magic chef
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
wwt
