Anonymous Posted on Mar 03, 2013
Error code c-2152 - OCE Office Equipment & Supplies
Adorjani Laszlo
Level 3:
  • OCE Master 1,316 Answers
  • Posted on Mar 04, 2013
Adorjani Laszlo
OCE Master
Level 3:
Answers
1316
Questions
Helped
469097
Points
2563
C 2152 : Transfer belt separation.Check the main motor connector for proper connection,check the image transfer pressure/retraction position sensor and clutch.For reset the error turn OFF the copier press and hold pressed the Utility key and turn ON the copier,wait to Trouble reset message appaire on the display and release the utility key and touch the trouble reset ,turn OFF the copier ,wait 1 minutes and turn ON.
TROUBLE CODE : C-2152 IN KONICA MINOLTA - Konica Minolta PRINTER
C-2152 is a trouble code that may be displayed on some Konica Minolta printers. This code generally indicates a problem with the printer's fusing unit, which is responsible for bonding the toner to the paper.
Possible causes for this error code include:
  • A malfunctioning or damaged fusing unit
  • Toner or toner waste accumulation on the fusing unit
  • A faulty thermostat or temperature sensor in the fusing unit
  • A problem with the power supply to the fusing unit
To troubleshoot and fix this error, you may need to perform the following steps:
  1. Check the fusing unit: Inspect the fusing unit for any visible damage, debris, or toner accumulation. If necessary, clean the unit and check for any loose or damaged components.
  2. Replace the fusing unit: If the fusing unit appears to be damaged or malfunctioning, it may need to be replaced.
  3. Check the power supply: Make sure the printer is properly connected to a working power outlet, and check the power cord for any damage or loose connections.
  4. Check the thermostat and temperature sensor: These components are responsible for regulating the temperature of the fusing unit. If they are faulty, they may cause the C-2152 error code to be displayed.
Bizhub C250 error code C-2152
Check your transfer belt and roller (sponge looking roller on the right side door the transfer is across from it in the machine take it out re-seat both of the them., if not will need a tech open close front door reset the code
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Replace N with a numeral that makes the sentence true 492-N=2152
492-N=2152
2152-492 = 1660
492-1660=-2152
492-(-1660)=2152
N= -1660
6helpful
Error code 2152
Trans belt retraction failure. Its a common error that can be reset by opening and closing the front door with the machine on.
Look in the trouble history and if has happened often, better order a new belt.
2answers
Radio code
Is there a question or definition.
Radio code - police band coded language, CB user's jargon, coded messages sent in cryptic radio traffic or error codes found in some car electronics.
3helpful
3answers
Error code c2152
good to
Imax Konica Minolta C451 Bizhub
I have a problem is the cod C2151 what to do Thanks
6helpful
Error code C-2152 on C351 Bizhub All in One printer
C2152: Transfer belt separation
it seems that it the you transfer belt. to be sure, take the old one into the copier, swith off th copier, with 10 seconds or more, then swith on. the error code will disappear :-)
2helpful
Need raido code for 2001 daewoo leganga please
1165 1325 1341 1630 2145 2152 2346 2453 3116 3241 3451 3462 4156 4236 4265 4316 4353 4362 4513 4524 4553 4653 5224 5226 5241 5253 5256 5436 5624 5813 6253 6361 6461
Posts: 4 Radio Code List:
6361,LEGANZA 99
2253, 3116, 3451, 2152, 4362, 4316
4316, 4513, 4362, 1156, 2145, 1156
6451, 6361, 5624, 5241, 3346, 1165
3241, 4524, 5436, 5813, 3265, 5624
2453, 3462, 3251, 5445, 8253, 1156
2346, 4853, 6645, 5253, 1325, 4136
3116, 3221, 2151, 5312, 2654, 4314
6234, 4356, 1415, 1435,1156, 1651
6361
2152 1165 4362 5813 4513 5241 4316 1651 5346 1341
3241 1652 4524 6361 2145 5436 1857 4353 5632 3451
1638 1156 1636 5324
2answers
Error Code C-2152 wen i power the machine at begin this messge was apear c-2152
what model bizhub you have, 350 B/W or some other? cant find this code for this machine. sorry
4helpful
2answers
Error Code C-2152
if you interested for complete service manual downolad at www.eserviceinfo.com
Top OCE Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
Sudeep Chatterjee
Sudeep Chatterjee
Ngoro
Are you an OCE Office Equipment and Supply Expert? Answer questions, earn points and help others
