I was given a Proform 380 treadmill but I don't know where the safety key slot is located.
Download the owner manual for free www.fitness.manualsonline.comGod bless you
SOURCE: Proform 765 EKG
If I understand correct, the treadmill will not run correct unless you have the safety key in. Well yes this is correct because once the safety key is removed the treadmill will stop. If your treadmill is running extremely fast just by turning it on, you may need a new speed sensor. www.AtlantaFitnessRepair.com
SOURCE: Treadmill LED Track does not go to start with key inserted
I pulled the safety switch out, and the elevation is stuck on 10 degrees
SOURCE: I have a Proform 380 Treadmill. When the treadmill
If the walking belt is off-center, first remove the key and UNPLUG THE POWER CORD. If the walking belt has shifted to the left, use the allen wrench to turn the left rear roller bolt clockwise 1/2 of a turn; if the walking belt has shifted to the right, turn the bolt counterclockwise 1/2 of a turn. Be careful not to overtighten the walking belt. Plug in the power cord, insert the key and run the treadmill for a few minutes. Repeat until the walking belt is centered.
SOURCE: need user manual for ProForm 380 CS treadmill
PLEASE go to :
www.proform.com go to customer service and then parts & manuals . you must give the model and serial number for to download free.
sincerely.
SOURCE: My Proform 380 treadmill will
ADJUST 1) Reed swithc and optic disk.
If after you did these adjustments Not work, replace the sensors.
