Am getting an error code on Krups xp 7240. What can i do to get rid of it. Thanx.
Edwin.
The error 06 happens because one of the services – Rinsing, Cleaning, Descaling or Replace Water Filter is out of date.
Start in a sequence and go through ALL services. Go to “Machine Information” in “Programme” Mode to ensure that “Last” reads zero or a maximum of something below 10 and your machine will NO longer give start up problem. Please report it if this still occurs, because a computer reset can be done.
SOURCE: krups xp 7240 cofee machine
6
Pump in actuator down phase
The flow has not dropped (> 50ml/min)
after the actuator has been filled to the
maximum (80ml); there is a water
leakage and the actuator does not fill
Look for the leakage source:
hoses, actuator, priming valve?
Switch or distributor switch
control fault: incorrect detection
of cams error in distributor
position in cylinder descent
phase.
Flowmeter hoses changed over
Distributor problem (leakage at
drain ..)
Faulty connection between the
2 picto boards
If no leak detected, replace
power board V26 with V29
SOURCE: i need a manual for krups xp 7240, krups xp 7200, krups xp 7230
I have the manual, send an email to me at inouside@hotmail.com and I will reply to you with the manual in pdf format.
