That's a fuser warm up error. Likely either a blown fuse, lamp or thermistor. Fuser is usually replaced as an assembly, and code can only be reset in "service mode" after the cause is fixed.
I had the same problem, but solved it. You have to connect your printer SP210 to your computer. Search (in Windows) "Smart Organising Monitor Status" Select Printer (new dialog box) Click OK (see the error code SC545) Click on User Tools Printer Configuration (Access Code is Admin074) Find Fuser SC Reset under Maintanance Click Ok Close Restart your printer Your problem is solved now
OR
Without connecting your printer to Computer (you can do this):
Turn on the printer Press C (Red colour centre) button once Enter 107 (nothing will be shown) Press the Green (Coping) button for 5 seconds See the Display --> Select Engine Maintenance Select Ok Select Fuse SC Reset (press down arrow - at down you will find it) Execute (by Pressing the Down Arrow) Done Restart your printer. Your problem should be solved....
Hello, you´re found problem in the fusion unit. Clean the thermistor, and try again. Before try it, most reset the Sc code with service code....Good Luck!
SC545 and SC 546 are fuser temperatyre error. pls. check thetmistor/ thermostats, connectors if thernistor are deffective replace thermistors. after replacement or checking of this parts do the SC reset. 107 # turn off copier then on after 5 sec.
You need to check 3 cause for that error:
- hot roller thermistor out of position
- fusing lamp broken (can you see the lamp going on at startup?)
- thermostat broken
If you are just a user, without any technical knowledge, i advise you to call a Ricoh Support Service.
you have to go into the sp modes to clear this code .pres the yellow c then 107 and hold down the orange c , do this all in sequence , it wil go in the sp modes and show copy sp .enter there and switch the power off wait 5 seconds switch back on
